iFi Audio Nano iDSD discussion + impression
Dec 1, 2016 at 3:59 AM Post #1,711 of 2,063
  look at the Streacom f5 case - http://www.streacom.com/products/fc5-od-fanless-chassis/
also you need more than a raspberry to process dsd256 / dsd512 upsampling
and with a decent mobo, psu and the right connections you can eliminate the interference
otherwise you pay big $$$ for the same functionality - see antipodes http://antipodesaudio.com/
Actually I have been temped to buy from Antipodes their DS series for years.
But it has more function then I need the internal DAC and internal HDD plus all the ability for networking and multi-room.
At one stage Antipodes has plan to release low cost model does not has DAC and HDD.
But that has been dropped.
I don't know when my Fiio X3 broken I might get Antipodes DS or Fiio's next DAP maybe it has USB out.
Note: I don't like Fiio's internal DAC it sound sharp.
Dec 7, 2016 at 5:52 AM Post #1,712 of 2,063
Hi all,
I am a new owner of iFi nano iDSD, and just can agree that it sounds great. I use it as a DAC connected to the  Mac Mini and next to a power amp, with original USB and RCA cables.
Unfortunately, I started to get sporadic playback stops and resets, which sometime coincided with placing my arm close to the iDSD but not even touching it. First blamed vibration and cables, but apparently they were fine. Finally I was able to trace down that this erratic behaviour was clearly dependant on two factors - my arm/palm within 5-10 cm distance from iDSD and … my Icebreaker merino wool t-shirt on myself. Wearing noname cotton one rescued the situation.
Of course, I am aware about static electricity and the fact that discharge can ruin delicate equipment, but there definitely was no discharge, simply exposure to electric field by approaching hand.
So I wonder whether there might be a proper way to connect iDSD to a ground or other means how to protect the device. Wearing antistatic bracelets is out of the question :)
Dec 8, 2016 at 10:53 AM Post #1,713 of 2,063
  Hi all,
Please use our STS form, which can be found here: http://support.ifi-audio.com/
That's the shortest way of handling this matter.
Dec 9, 2016 at 6:37 AM Post #1,714 of 2,063
Nano iDSD ‘LE’
Pocket Rocket.
Southport, UK – 9th December 2016
Small, dark and handsome
The original nano iDSD redefined the US$200 price class for sonics with a worldwide following of portable/home music lovers enjoying all formats from DSD to MP3.
The new nano iDSD 'LE' (Light Edition) in stunning dark titanium is a $129 reboot:
  • Same stunning ‘True Native’ Burr-Brown PCM/DSD chipset
  • Headphone power output of 130mW with 10-hour battery life
  • RCA outputs on analogue volume control
Below US$150, there is nothing as advanced as the nano iDSD LE:
Features
  1. Burr-Brown ‘True Native’ chipset
  2. AMR trickle-down ZeroJitter Lite® for low-jitter/phase-noise
  3. DC-Infinity circuit, DirectDrive® Servo-less circuit
  4. Battery-life ~10 hours
(Compared to original nano DSD, no SPDIF out, no filter switch and DSD256, has DSD128)
http://ifi-audio.com/portfolio-view/nano-idsd-le/
Specifications
  1. Power Source:                     Battery/USB Bus power
  2. Battery Life:                          ~ 10 Hours playback*
  3. Formats:                              44.1/48/88.2/96/176.4/192/384KHz PCM
               2.8/3.1/5.6/6.2 MHz DSD
         353/384KHz DXD
          Bit-Perfect DSD & DXD DAC by Burr Brown (1-DAC Chip; 2-Channel; 4-Signals)
  1. Input:                                      USB 2.0
  2. Output                                    Audio RCA
        3.5mm Headphone
  1. Dynamic Range:                  >104dB
  2. THD &N (35mW)                 < 0.005%
  3. THD &N (Line)                     < 0.005%
  4. Output Power (16R):           > 130mW
  5. Output Voltage:                    >1.65V (>100Ω)
  6. Output Impedance:(Zout):  <1Ω
  7. Power Consumption:          < 3W (charging battery and playback together)
  8. Dimensions:                         106(l)x67(w)x28(h)mm
  9. Weight:                                162g(0.43lbs)
# requires Camera Connection Kit or OTG adapter. Cable sold separately.
Specifications are subject to change without notice.
The retail price of the nano iDSD LE US$129 (ex-tax) or €149/£129 (incl VAT).
Update: Music Direct has it on the launch pad:
https://www.musicdirect.com/headphone-amp/iFi-Nano-iDSD-LE-DACHeadphone-Amp
Dec 9, 2016 at 7:12 AM Post #1,715 of 2,063
Nano iDSD ‘LE’
Pocket Rocket.
Features
Specifications
               2.8/3.1/5.6/6.2/11.2MHz DSD
         353/384KHz DXD
  1. Input:                                      USB 2.0
  2. Output                                    Audio RCA
        3.5mm Headphone
That was quick - I wanted to reply there must be some error regarding DSD128 and DSD256 as stated in initial post ... well done iFi !
Dec 9, 2016 at 10:37 AM Post #1,718 of 2,063
Nano iDSD ‘LE’
Pocket Rocket.
Features
Specifications
         353/384KHz DXD
  1. Input:                                      USB 2.0
  2. Output                                    Audio RCA
        3.5mm Headphone
Which filter is it using internally?
Dec 9, 2016 at 6:18 PM Post #1,720 of 2,063
  sorry posted in wrong thread.
Since you're sorry, we forgive you
Dec 18, 2016 at 11:43 AM Post #1,724 of 2,063
Whoa!!  This is around 20 post/day.  You guys better start giving stuff... :-)~
20 posts per day? Could you please share your math with us? We lack 44 posts to hit the number, at least that's what our profile says...
Dec 18, 2016 at 12:30 PM Post #1,725 of 2,063
Oh, I was referring to this thread, which has 1724 posts. :-)  (2000 - 1724) / (31 - 18) = 21.2.
