mdiiorio
Yes, I have two. One on the switch port where the router cable is, and the other on the back of the Fire Cube.You’re going to have to experiment, see what location gives you the best audio and/or video improvement combo. It’d be simpler if you had a couple to be honest. If you had two my recommendation would be one pre switch (plugged into switch on router side) and one on port of switch to fire cube or plugged directly into Cube.
Actually if you just had one I’d say try it in the first position I describe. Main thing is to experiment see what you see, hear what you hear, whatever you prefer is best.
I also have two HDMI iSilencer, one on my receiver and the other on the tv.
Let's see how this combo works!
