Guy Fawkes
@iFi audio
I bought an iDefender + to solve a ground loop problem from a Dell AIO and a DAC and Amplifier both powered from the mains, my chain is as follows:
PC -> USB-C to USB-B Cable -> Aune S8 DAC -> RCA connections -> Aune S7 Pro -> Headphones
If I insert the iDefender+ in the chain between the PC port and the USB-C cable without using any additional 5V power adapter supply to the iDefender+ the Ground Loop problem is not solved, if instead I insert an additional power supply, white light turn one and the Gound loop is broken correctly.
The question is why to get the result I am forced to use the additional 5V power adapter supply to the iDefender+ considering that the DAC and Amplifier are both mains powered? in this case it shouldn't be necessary and I should get the result anyway.
Thank you
Thank you
