Guitarjon
Hi,
I just got an iDefender+ for my music home studio setup. I use my Fractal Audio Axe Fx III as my main USB audio interface and a brand new W10 PC. There is noise coming through the USB to the soundcard and I had temporarily elliminated that by cutting off the ground off the USB cable. This indeed solved the problem. The iDefender+ seems like a much better solution. It works indeed, albeit it only completely elliminates the noise with a regular old 5v adapter. I tried another adapter, and that didn't work. Without the adapter the noise is less, but not gone.
The developer of Fractal Audio made a few statements on removing the ground off the USB to the interface and I'm curious how seriously I should take these statements or if these even apply with the iDefender+. This is what he said:
While the 5V may not be used by the device for power it's still necessary. The peripheral uses the 5V as a detect. 5V is connected to the peripheral's Vbus pin which tells the peripheral that a host is connected. Disconnecting the ground is dangerous. While it can solve noise due to a ground loop it increases the risk of an overvoltage on the Vbus and data pins which can damage the USB controllers (this is why the spec calls for ground at both ends). The correct way to solve a USB ground loop is to make sure the peripheral and PC are plugged into the same power strip. Keep all power cables bundled close together as possible.
Obviously his last suggestion didn't work for me, that's why I think the iDefender is my only option....
I'm looking forward to your reply.
