Yes you can And you could use 5.20 as well, very good sounding !
Glad you enjoy both! Yes, you can use the 5.3c on the Sig ~ let us know what you think about the differences in sound when you A/B the firmware!
@iFi audio, because the Signature is always running on battery power as opposed to AC, there's no need for a linear power supply or iFi's own iPower X, which is why there's no iPower device included in the box, correct?
Yes, correct! It was always designed to run on battery power as opposed to AC.
You can keep the USB C plugged in while using it but it isn't normally recommended for battery longevity reasons.
I got the Signature in the mail today and have been listening to it for a few hours. Based on the comments in this thread, I let the iDSD warm up to room temperature before use and inserted the iGalvanic 3.0 in between my Mac mini and the iDSD Signature. I'll try it without the iGalvanic later.
First impressions:
Using my Senn HD800S headphones, I began with Adele's 25 to test the treble response and didn't cringe. Nice job, even when the Signature was barely warmed up. Updated the firmware to 5.3c and switched between the Bit-Perfect and GTO filter. Next up, hi-res Beck, K.D. Lang, the Herbie Nichols Trio, and a trusty Bach Concerto with Stern and Zukerman. All sounded great on the HD800S with the music slightly warmed by the Signature. Transients are nicely snappy with both filters. Decent amount of bass (even on the 800S) and good control over it. Definitely more definition and clarity than with my previous iDSD BL. My HD800S were very happy in Eco power mode with the volume turned to 12 o'clock.
After two hours of listening, I'm impressed. Need to listen more.
Same here: iDSD + HD800S and I'm still very happy with it. One question about the firmware version: can you give some more insight how these differ? For now I use the iDSD as it was delivered. Not sure about what effect on the sound the other version will have....
First impressions:
Using my Senn HD800S headphones...
For me it sounds a bit more natural with acoustic instruments or vocals, using the 5.20 firmware. I use a Macbook Air, Audirvana, Direct mode, DSD or Hi res PCM files, DT1770.Same here: iDSD + HD800S and I'm still very happy with it. One question about the firmware version: can you give some more insight how these differ? For now I use the iDSD as it was delivered. Not sure about what effect on the sound the other version will have.
The firmware I chose to use, version 5.3c, replaces the minimum-phase filter option on the iDSD Signature with iFi's "Gibbs Transient Optimised" (GTO) digital filter. They have an explanation of the GTO filter here on their website. It's intended to present a more "nautral" sound than the other filter options on the Signature.Same here: iDSD + HD800S and I'm still very happy with it. One question about the firmware version: can you give some more insight how these differ? For now I use the iDSD as it was delivered. Not sure about what effect on the sound the other version will have.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Yes I tried the GTO filter but prefer the standard filter with 5.20. Just a mater of tasteThe firmware I chose to use, version 5.3c, replaces the minimum-phase filter option on the iDSD Signature with iFi's "Gibbs Transient Optimised" (GTO) digital filter. They have an explanation of the GTO filter here on their website. It's intended to present a more "nautral" sound than the other filter options on the Signature.
The 5.3 firmware versions do DSD256/PCM384/MQA.
The 5.2 firmware versions do DSD512/PCM768/No MQA.
I downgraded the firmware to 5.20 and listened to music for a while. In comparison, think the sound is a little more laid-back/mellow with 5.3 versus 5.2. 5.2 is a bit more forward, so if 5.2 is front row seats, 5.3 is mid-row seats. I can see why 5.2 might sound more exciting than 5.3.Yes I tried the GTO filter but prefer the standard filter with 5.20. Just a mater of taste
Which firmware comes installed on the Signature?
