I'm curious why there are no separate power output (and other) specs for the balanced and SE outputs?
Do they both have the same power output levels and specs?
If so, does that mean that the 4.4mm balanced output is a 'convenience' output jack (to simply allow the use of a cable with a 4.4mm connector) that doesn't offer any increase in power output or reduction in noise levels compared to the SE output?
Thanks.
________________
- Edit - I appears that the iDSD Signature's 4.4mm output uses iFi Audio's S-Balanced feature which allows the amp's balanced output to have 50% less crosstalk than the amps unbalanced output, but it doesn't offer any gain in power output or reduction in noise level, like a conventional balanced output circuit would.
For a more techincal description, click on the link in the following post.
Thanks.
________________
