iFi audio iDSD Diablo - A portable reference done our way!
Dec 1, 2022 at 3:51 AM Post #2,566 of 3,058
What’s wrong with just using the firmware it comes with. I have wanted to purchase Diablo, but hesitate because don’t want to play around with firmware changes.
Also how is sound quality vs iFi gold bar?
Dec 1, 2022 at 7:10 AM Post #2,567 of 3,058
It's perfectly fine to do so, there's nothing wrong with the stock firmware :)
That's a good question, but I'll leave it up to those folks who were able to compare them :)
Dec 1, 2022 at 7:23 AM Post #2,568 of 3,058
iDSD Diablo: revel in the detail
Dressed in devilish red, iFi’s new top-of-the-range transportable DAC/headphone amp sports a powerful engine under the hood, expertly tuned to deliver an exhilarating sonic performance
Southport, England – iFi ushers in the New Year with the best battery-powered DAC/headphone amp the company has ever produced – the devilishly brilliant iDSD Diablo. Engineered to sit proudly at the top of iFi’s illustrious range of mobile and transportable devices, the Diablo is built for the purists – the true headphone enthusiasts who crave pure, unadulterated sonic performance.
With dimensions of 166x72x25mm, its size is similar to DAC/amps in iFi’s long-running, transportable micro iDSD series, with a built-in, quick-charge-compatible battery that makes it easy to move from desk to living room to travel bag. Its sleek new design and fiery red finish, however, mark it out as distinctly different.
Like a high-performance sports car designed for uncompromising speed, the iDSD Diablo sets aside facilities offered by other iFi DAC/headphone amps – sonic tailoring options and Bluetooth connectivity, for example – to focus on pure sonic power, featuring ultra-high-quality circuit components and the ability to drive any headphones on the planet with aplomb. Simply connect your digital source via USB or S/PDIF, plug in your headphones and prepare for a riveting musical ride from this elite-class digital audio engine, expertly tuned to achieve captivating speed, scale and dynamic range.
DAC’s entertainment
The iDSD Diablo’s digital stage incorporates a Burr-Brown DAC chip that iFi uses extensively, selected for its natural-sounding ‘musicality’ and True Native architecture. Here, two of these chips are installed in a custom ‘interleaved’ configuration – this enables four pairs of differential signals (two pairs per channel) which lowers the noise floor, improves channel separation and enhances the DAC’s ability to resolve fine musical detail and micro-dynamics.
iFi’s experience with this Burr-Brown chipset means it knows how to make the most of it, but the creation of an exemplary digital stage involves more than the selection of a particular DAC chip. One such critical component is the XMOS chip that processes the audio data received via the USB and S/PDIF digital inputs. The iDSD Diablo uses a new low-latency XMOS microcontroller with greatly enhanced processing power – compared to the current generation of eight-core chips, this new 16-core IC delivers double the clock speed (2000MIPS) and four times the memory.
iFi’s in-house digital development team has programmed the XMOS firmware to optimise sound quality and ensure a perfect partnership with the DAC circuitry. Extensive jitter-eradication technologies are also applied to the digital stage, including an enhanced version of iFi’s GMT (Global Master Timing) femto-precision clock featuring a new crystal oscillator.
Every music format at the highest quality
Hi-res audio support is state-of-the-art, handling PCM data to 32-bit/768kHz, all levels of DSD up to DSD512, and single- and double-speed DXD.
Thanks to the Burr-Brown DAC chip’s four-channel True Native design, PCM and DSD take separate pathways – this enables DSD, as well as PCM, to remain ‘bit-perfect’ in its native form right through to analogue conversion. This is often not the case with DAC devices from other brands – even if DSD compatibility is stated, many such DACs convert DSD signals to PCM.
MQA – the hi-res streaming codec, as used by Tidal’s ‘Masters’ tier – is also supported through the USB and S/PDIF inputs, with full decoding of MQA files up to 384kHz thanks to the processing power of the new 16-core XMOS chip. This means that the full ‘three unfold’ decoding process is performed internally, as opposed to only the final unfold in the manner of an MQA ‘renderer’. Globally, MQA has become an important consideration for any comprehensively equipped DAC; for Tidal Masters subscribers, the iDSD Diablo is a great way to make the most of the superior sound of which this streaming service is capable.
PureWave – balanced circuit design for the purest sound
The digital stage is only half the story in any DAC/headphone amp; when it comes to the crucial analogue circuitry, many such devices fall short. Balanced, differential analogue circuit design has long been championed for its ability to reduce noise and cross-talk within the signal path by fully separating the left and right channels. However, this is more complex and costly than single-ended circuitry, and so has traditionally remained the preserve of high-end hi-fi components.
iFi has gradually introduced fully balanced circuit design across its range – first in the flagship Pro Series components, then in the entry-level ZEN Series devices. The company’s two newest DACs, the mains-powered NEO iDSD and transportable iDSD Diablo, benefit from further refinement of their balanced, symmetrical dual-mono topologies with short, direct signal paths. iFi calls this circuit concept ‘PureWave’, referring to the sonic purity it achieves thanks to exceptional linearity and infinitesimally low levels of noise and distortion.
Powerful amplification delivers musical gratification
Already renowned for the performance of the amp stages in its DAC/headphone amps, iFi has ensured the iDSD Diablo is its best-ever transportable amplifier, designed to deliver reference-level sound. Able to drive all manner of headphones with ease, from highly sensitive in-ear monitors to current-hungry planar headphones, it delivers prodigious power (up to 5000mW), propulsive energy and engaging dynamics, coupled to a remarkable ability to resolve fine texture and detail.
The great variation in the electrical characteristics of different headphone/earphone types is accommodated by the provision of three settings enabling the user to adjust power and gain to suit whatever the amp stage is tasked with driving: ‘Turbo’ ramps up the level of drive for current-hungry headphones, ‘Eco’ dials down the power to suit high-sensitivity in-ear monitors and/or extend battery life, and ‘Normal’ sits between the two.
High-quality components are used throughout the iDSD Diablo’s circuitry, utilising its larger form factor in comparison to smaller, pocket-sized DAC/amps. Custom ultra-low-distortion MOSFET op-amps feature in both the digital and analogue stages, together with a hand-selected range of capacitors including the multilayer ceramic type TDK C0G and aluminium-polymer type Panasonic OS-CON. MELF thin-film resistors and inductors from Taiyo Yuden and Murata also feature in the circuit design.
These are all more costly than commonly used circuit components, but class-leading qualities such as low ESR (Equivalent Series Resistance), high stability and low distortion pay great dividends in terms of sound quality. Many hours of listening tests, alongside rigorous analysis in the lab, has determined the optimum circuit design to deliver maximum musical enjoyment.
An important aspect of the iDSD Diablo’s circuit design is its direct-coupled nature (no coupling capacitor is present), achieved without a conventionally applied DC servo; iFi calls this design Servoless Direct Drive. Also important is the use of a high-quality analogue potentiometer to control volume – its sonic transparency compared to chip-based volume controls makes the most of the clarity and resolution of the amp stage.
OptimaLoop – negative feedback that is purely positive
‘Negative feedback’ is used in amplifier circuits to compare the output signal with the input signal and correct errors, in order to control gain and reduce distortion. For sound quality, this is positive; but commonly applied, one-size-fits-all ‘global negative feedback’ can highlight different problems whilst solving others – corruption of the error signal, phase shifts, group delay and so on can all have a negative impact on sound quality.
Recognising that different parts of a circuit benefit from specifically optimised feedback loops, iFi has developed a negative feedback system that is much more accurate than the usual approach. This incorporates multiple feedback paths instead of one global loop, each path optimised for a particular function and working synergistically with the others to deliver optimal overall performance. iFi calls this new configuration OptimaLoop.
This power does not corrupt
In keeping with the iDSD Diablo’s focus on pure, unadulterated performance, much attention has been applied to the power supply circuity. Battery power provides a theoretical performance advantage over mains power, with ultra-clean and stable DC current avoiding the issues that can be introduced by mains electricity with its dips, spikes and noise-inducing RFI/EMI pollution. There are also potential sonic downsides to battery power, however, resulting from low output voltage and inconsistent output impedance as batteries discharge – these issues are fully tackled by the iDSD Diablo’s design.
In order to make less efficient headphone types sing – planar magnetic designs, for example – the voltage needs to be stepped up from 3.7V to +/- 15V. This is achieved through the use of a step-up converter running at 1.2MHz – a frequency far beyond audibility that is easier to filter than a typical switch-mode supply, enabling high linearity and ultra-low noise.
High-bandwidth power supply circuity is dedicated to each critical part of the iDSD Diablo’s design, with independent linear regulation delivering excellent PSRR (Power Supply Rejection Ratio) performance. The headphone amp stage eschews IC regulators in favour of Panasonic OS-CON capacitors, delivering 2320uF between them. The DAC section benefits from an ultra-low-noise regulator with additional passive filtering, reducing high order harmonic distortion and, in turn, jitter. Even the USB input stage benefits from dedicated regulation and multistage filtering, and the microprocessor control circuitry (often a local source of digital noise) has separate regulation, too.
Get connected
At the front of the unit, alongside a standard 6.3mm single-ended headphone socket, resides a 4.4mm Pentaconn output for headphones offering balanced connection. An increasing number of high-quality headphones and in-ear monitors either come so equipped or give the option of detaching the cable and upgrading to a 4.4mm Pentaconn connector (this output is particularly recommended for tougher headphone loads). In terms of power, the balanced headphone output delivers 12.6V/4980mW into 32 ohms and 19.2V/611mW into 600 ohms, while the single-ended output supplies 8.8V/2417mW into 32 ohms and 9.6V/153mW into 600 ohms.
At the back of the chassis are two digital audio inputs: USB-A and an S/PDIF socket that accepts both electrical and optical signals, the former via a 3.5mm connector and the latter via a supplied adapter. Unusually, the USB-A input features a ‘male’ connector, rather than a typical ‘female’ port – this arrangement provides greater mechanical integrity than the USB/Micro USB ports commonly used by other DAC/headphone amps. It also offers an advantage to users of iPhones and iPads with Lightning ports, because it accepts Apple’s Lightning to USB Camera Adapter directly without requiring an additional female-to-male USB adaptor. A separate USB-C charging port is also provided, along with a fixed line-level 4.4mm Pentaconn balanced output to connect an external amp.
A package worthy of reference status
In keeping with a reference-level product, iFi has been generous with the accessories supplied with the iDSD Diablo. The DAC/amp may be powered from the mains, as well as by its built-in battery; in order to ensure optimal sound quality when hooked up to the mains, iFi includes its iPower 5V AC/DC adapter, which engenders significantly less noise than other similar devices thanks to Active Noise Cancellation and sells separately for £49.
Also included is a 4.4mm Pentaconn to XLR balanced interconnect cable, enabling the iDSD Diablo to be connected to an amp and speakers (or a pair of active speakers) with balanced XLR inputs. Other supplied connectors include a short (15cm) USB-C to USB-A audio cable, as well as an extension cable – all USB3.0 compliant – plus a USB-C charging cable and an adapter to connect headphones with a 3.5mm jack to the 6.3mm single-ended output. Even a travel case is included.
In addition, the first iDSD Diablo production run includes iFi’s iPurifier3 in the bundle – retailing separately at £129, this USB ‘noise-buster’ is designed to tackle all aspects that degrade sound quality over USB thanks to a precision mix of tech including Active Noise Cancellation. It all adds up to a package of accessories worth around £300.
Delivering devilishly good sound for headphone lovers, iFi’s iDSD Diablo is available from selected retailers from Friday 15th January at an RRP of £899, (€999, $899).
DAC’s entertainment
Get connected
DAC’s entertainment
Get connected
I have positive experience with Ifi products, not the least with my iDSD Signature. I have some ideas I would like to discuss with Ifi if Ifi is willing to listen. How do we get in touch?
Dec 1, 2022 at 10:41 AM Post #2,569 of 3,058
Please send me a PM, thanks!
Dec 1, 2022 at 12:54 PM Post #2,570 of 3,058
If you felt the need to perhaps try the GTO filter changing firmware is very simple.
In terms of sound quality to my ear the Diablo is a step up from Go Bar. More effortlessly dynamic and smooth without being warm or lacking detail. At the same time not overly analytical or dry.
To me Go Bar is a bit “edgy” sounding by comparison, not harsh but less organic in some way.
I recently sold off a Schiit Asgard 3 and a Woo Audio WA6 tube amplifier because to me the Diablo simply sounded better with my headphones.
It has tons of power but is very quiet with no noise floor problems, a very black background. Go Bar is quite noisy with even only moderately sensitive IEM.
Dec 17, 2022 at 9:07 PM Post #2,571 of 3,058
I’m thinking of getting the Diablo. I use the idsd signature most days while working. Love the thing. Even though I have the hugo 2, bifrost2, mojo2 and other stuff, it’s the idsd signature that I use for most of my listening. Just love how it sounds. I’m thinking of being the Diablo to go with the signature and not to replace it. That way I don’t have to worry about the Diablo being too powerful for my iems. I’m guessing it will be good with my lcd i4 though
@gazzington, just curious if you pulled the trigger on the Diablo? I'm currently in the same boat. Have the iDSD Signature and love the sound, even over the Mojo 2 with Aeolus. Looking to hear what other people who've upgraded from the Signature feel it's worth it or not.
Anyone else feel free to comment. Looking to see what it adds. I'm curious if it increase the soundstage and instrument placement or digs deeper in bass.
Dec 20, 2022 at 1:06 AM Post #2,572 of 3,058
I have a scientific question.
Is a digital signal reduction by using the likes of UApp or Roon (headroom function) comparable to an analogue one (turning the volume pot down).
Background is the known effect of channel imbalance in the lower Diablo volume pot positions which leads to a normal listening volume on the lowest pot position where no channel imbalance is occurring with my Denon AH-D9200.
By decreasing headroom by e.g 8db in Roon I am now able to listen with lower volume on the same pot position and therefore gaining usable volume range on the Diablo.
Who knows if that approach is implying any downsides ?
PS: using the advertised Ifi Iematch is affecting the frequency of most earphones besides planars because of the increased impedance so that's not an option for me for dynamic drivers.
Dec 21, 2022 at 4:45 AM Post #2,573 of 3,058
I don't know enough to give a well-written fully detailed explanation, but in layman's terms: analoge volume control decreases and increases the power for the amplifier section. by doing volume control in the digital space, you don't change the power available, but you reduce the signal volume. In most usecases this difference is barely -if not at all- noticable to your ears.
Dec 21, 2022 at 5:54 AM Post #2,574 of 3,058
so taking what CH23 just a little further in ‘logical thought’, is that YES you are RIGHT! (@FooFighter)-
you will not get the shift as using the iematch equals + you will get the ability to be closer to the ‘threshold of sound’ low volume levels without the channel imbalance ‘down low’
All you are giving up is ‘not using the headphone amplifier in a less than ideal zone’ (the manufacturer has quoted time and time again to keep the volume pot between 12 and 2 for ‘optimal sound’.
Techincally you may be burning (an insignificant amount) more power, and yes, you technically give up some of the ‘technical spec’ regarding absolute dynamic range..
Planning on listening to jet engines taking off whilst picking out the triangle at the back of an orchestra?
No.. then, ‘No’ -nothing LOST!
Great solution btw!
edit: for the record you’d still hear the jet engine and the triangle.. just the dynamism between them might be squished?
the only concern I would have for any ‘digital alteration of the feed’ is usually to do with any form of sample rate conversion.
The enjoyment you gain from this setup would completely outweigh any theorhetical loss due to its implementation.
As a person who used to use some Sennheiser RS170 headphones (that do ADC and DACing AGAIN to whatever is fed them…)- I seriously doubted the Diablo could vastly improve their sound (over say a Fiio BTA30 etc).. - how wrong I was.
this is a lot more destructive to the signal that anything you are doing, so I’d say.. you are ‘good to go’
Dec 28, 2022 at 1:19 AM Post #2,576 of 3,058
I have 2 questions about the Diablo:
1/ Can I use only the amplifier section in Diablo as an external amplifier?
2/ Does it have "desktop mode"?
Thanks!
Dec 28, 2022 at 6:59 AM Post #2,577 of 3,058
Thanks!
1: yes, the 'line out' port can also be used as a 'line in' port if no USB data connection or spdif connection is made. be aware that it is a balanced line in/out, and to use unbalanced devices you will need to leave L- and R- disconnected, and use ground instead.
2: what is a 'desktop mode'?
Dec 28, 2022 at 7:11 AM Post #2,578 of 3,058
I think he means a specifically powered mode like M17.
Question is if a wired powered Diablo has sonic benefits over a battery powered one as this topic has come up earlier yet in this thread
Dec 28, 2022 at 8:37 AM Post #2,579 of 3,058
all power goes through the battery, when you use it in desktop mode at most the battery will function as a power filter. (DC via USB C in -> battery -> diablo pcb)
Dec 28, 2022 at 1:20 PM Post #2,580 of 3,058
I don’t know anything about the technical aspects of the inner workings but I am not convinced the battery is in the power circuit once it us charged and a power supply is attached.
My reasoning as below:
With a low power PSU (actually the one that it ships with in my case) the Diablo can be forced into protection mode at a much lower power/volume level than on battery power. Logically that means the PSU is limiting the current available, if the battery was still providing the power why is the output power available less on a low power PSU.
Conversely on high power PSU (Samsung 25 watt) the Diablo will not go into protection mode driving high current demand low impedance and low sensitivity planars even full volume on Turbo. When on battery only the Diablo will shut down long before that level.
IfI actually acknowledged that on a high power PSU the current output from the headphone jacks is higher than from the battery since the battery is the limitation that a PSU can overcome. They said at the expense of heat but my observation was that if the PSU is powerful enough so that the battery isn’t called on at all (and once it is charged) the Diablo actually runs cooler. I infer that to be because the battery is not being called on to provide power and isn’t being charged so the battery isn’t creating heat.
That all seems a lot like a desktop mode to me but it would be nice if ifI could confirm either way.
Below are some screenshots of comments from ifI or their representatives that infer that the Diablo has a desktop mode that more or less bypasses the battery.
I wonder if the battery could be removed completely and some sort of wiring put in its place to complete the circuit and run the Diablo with no battery at all.
