greentea76
I can see only specific combinations (eg. 16/44.1, 32/96 etc.) when I set 32/192 (24/192 is not available) that is highest declared output from apple music, diablo is always white led. Although I play 16/44.1 that should show yellow led. this affects only apple music app that itself seems to not recognize external dac internally like roon or tidal do. it sends music to sound output set on mac os levelWhen setting the output bitdepth (ie 16/24/32) in the MacOS ‘Midi Control panel’, you are setting the highest supported bit depth that you wish to use.
You software on the computer will then be able to use all rates ‘up to‘ this setting.
(you don’t need to keep changing it here)
