deleted
i really like the Qudelix 5k as alternativeI figured out a fix until iFi has a decent firmware out with a respectable app. I got a pixel watch 2 promo with the pixel 8 pro purchase. Volur to FiiO BTR7 and the watch has spotify controls. The biggest thing for me was being able to pause and skip tracks and adjust volume without taking my phone out of my pocket. This does the trick. I don't mind the wire of the IEM if they are not tethered to my phone. Plugged into the BTR7 it's much easier to deal with. Fully wireless would be ideal, but the Go Pod have a few compromises. And since that case is so insultingly big, a small case with the BTR7 and the Volur inside is not much bigger. If the Go Pod case was a reasonable size and sleek design, that would be more points in its favor, but they under-engineered it, got lazy.
Just out of curiosity and for other members to be helped here, may I ask you what issues exactly are you facing with your GO Pod?I figured out a fix until iFi has a decent firmware out with a respectable app. I got a pixel watch 2 promo with the pixel 8 pro purchase. Volur to FiiO BTR7 and the watch has spotify controls. The biggest thing for me was being able to pause and skip tracks and adjust volume without taking my phone out of my pocket. This does the trick. I don't mind the wire of the IEM if they are not tethered to my phone. Plugged into the BTR7 it's much easier to deal with. Fully wireless would be ideal, but the Go Pod have a few compromises. And since that case is so insultingly big, a small case with the BTR7 and the Volur inside is not much bigger. If the Go Pod case was a reasonable size and sleek design, that would be more points in its favor, but they under-engineered it, got lazy.
Update:Just ordered these bad boys finally.
Judging by how people have described the sound I'm looking forward to oodles of thumping meaty bass on my OG Campfire Audio Vega's.
Hopefully I also have a completely pain free seamless experience like most fellow Samsung users on here seem to be having
I think you need to contact iFi Support with a detailed explanation of your issue. I think it is the best.They are the real deal. Need to figure out why gapless with a Shanling MO Pro is glitchy. Maybe the codec???
AptX classic is now working for me. All is good. Love these things!I think you need to contact iFi Support with a detailed explanation of your issue. I think it is the best.
The IE600 family has a recessed mmcx connection that is not compatible with regular mmcx. You have to ask iFi for a new recessed mmcx earhooks.Where can I buy the ifi go pod that comes with the mmxc connector for Ie600 family?
ThanksThe IE600 family has a recessed mmcx connection that is not compatible with regular mmcx. You have to ask iFi for a new recessed mmcx earhooks.
So
1. They don't sell them separately but they will send you them to you upon request?
2. They are not included with the latest hardware versions?
