neobandog1
double the power of W2Just L&P W2 without display, does it offer anything better?
I saw you just post review n8ii, how dose gold bar sound compare to n8ii?Not all iFi Burr brown DACs sound exactly the same.
As an example the Diablo is slightly different than the Gryphon.
The Go bar Gold ,to my ears, is sounding quite close to the Gryphon.
thanks for the information about the xbass. I prefer the xbass as it is now (although I seldom use) since my ier-z1r already has very good realistic bass so I may not update the firmware.I thought about that too but I went all yolo and installed it on to my gold bar. For some reason, the xbass seems more noticable now as before it used to be a subtle change. XBass + IMR BC = bass head bliss
ps. I keep the film on because fingerprints makes me mad lol
Now, it wouldn't be fair or appropriate to compare the Go bars to the $3700 Cayin N8ii.I saw you just post review n8ii, how dose gold bar sound compare to n8ii?
Sorry but I don't know anything about the iOS.I don’t get the so called IOS (iOS?) version for the GO Bar FW update. It contains a .dmg file which is a (to my knowledge) a MacOS disk image, and no iOS. Confused…
so 1.70/1.70a is not for gold?
XBass+ and XSpace are both analog circuit based. Changing firmware should have little to no effect on how both work unless there is something really wrong with the firmware.
I don't think that such a comparison makes any sense.
Both bars share the same firmware.so 1.70/1.70a is not for gold?
Then good for you, sell the N8ii and keep the Gold!the gold bar sounds better than n8ii with ier-z1r and plussound pph8
no the gold bar needs high quality transport and power supply that n8ii is doing very well in this regardThen good for you, sell the N8ii and keep the Gold!
If I send you another one could you possibly send me your N8ii?no the gold bar needs high quality transport and power supply that n8ii is doing very well in this regard
maybe Cayin can lend you longerIf I send you another one could you possibly send me your N8ii?
