iFi Audio Gemini3.0 & Mercury3.0 - The New Dynamic Duo
Nov 17, 2017 at 10:54 AM Post #16 of 31
Nov 17, 2017 at 2:46 PM Post #17 of 31
Yes you can. I've used the previous generation Gemini that way many times (and yes you can mix USB2.0 and USB3.0 ports and no I do not know which way round will sound better in your case).
Thank you for your reply. It brings me more questions. In this case Gemini work like single cable? If so, I think it doesn't work fully functionally. Mercury might be better choice. I wonder Gemini is good choice only for users they have micro/nano iUSB3.0 ?
Nov 17, 2017 at 3:46 PM Post #18 of 31
Both the Gemini 3.0 and the Mercury 3.0 are single cables. What makes the Gemini special is that physically separates off the USB power and data lines, which I've found improves sound with other double ended cables. This splitting means that you need two ports on your source to use the cable. If you can't make two ports available then the Gemini is not for you.
In this image, I believe that this is the chain:
Mac to Gemini 3.0 (£379) to iGalvanic 3.0 (£369) to Mercury 3.0 (£209).
It is possible that this is the chain with one element hiding behind the Mac:
Mac to Gemini 3.0 to iUSB3.0 (£195 for Nano, and £395) to Gemini 3.0. to iGalvanic 3.0 to Mercury 3.0
Nov 17, 2017 at 4:20 PM Post #19 of 31
I currently have the data end of Gemini plugged into my desktop PC and the power end plugged into an iPower 5V. The other end goes into an iPurifier2 and micro iDSD.
Nov 17, 2017 at 5:58 PM Post #20 of 31
I understand what glassmonkey and technobear said. I thought Normal PC cannot recognize which port is for data and for power. It must work like single head usb cable. But It was wrong. Gemini cable controls it, its not PC's task. So if two ports are available, I can use gemini cable. Thank you very much :D
Mar 29, 2020 at 6:44 PM Post #21 of 31
I use the Gemini 3.0 USB cable feeding data to DAC with the data side directly from my MacBook, and feeding clean power to DAC with the power side from a IFi Micro USB 3.0. It sounds better then sending data to Micro USB 3.0 first and then to DAC.
The Gemini 3.0 USB is a very good way to feed clean power to the USB DAC module in any DAC, and doing this it significantly improves the sound.
Mar 30, 2020 at 5:48 PM Post #22 of 31
I agree. It's interesting to what measures (cables, reclocking, galvanic isolation) the USB interface responds really well and how much better can it get.
Apr 15, 2020 at 9:40 AM Post #25 of 31
These shorties are not avialable. We made several for our own event usage only. Sorry!
Thank you for answer. I am sorry to hear that since adding 0.7m cable from iUSB to iDAC2 or iDSD micro while both units are on the same iRack less than 10 cm away is overkill especially for such nice setup that does not take a lot of space on my desk. It is not even about the price but more about usability in my case.
Apr 15, 2020 at 10:14 AM Post #26 of 31
I understand. Perhaps one day we will come up with a commercially available shorty USB cable. I'll let my team know that there's some demand for it.
Thanks for your input!
