Assationater
Fr cables succDongle DAC's that don't need adapter or have any visible cabling. Like the TC35 M2/Pro, just don't see enough options like that.
A DAC/preamp with balanced outputs preferably and a subwoofer output (2 RCAs?) with a good adjustable crossover filter say -24dB per octave for 2.1 home (PC) desktop listening. Maybe add adjustable delay for the sub as an option too. The only product that I see with this functionality is the MiniDSP Flex.Hey Folks,
Here's your chance to make your voices heard! Simple rules, pick a product that we don't currently make (CD Transport, DDC, LPS, Turntable?) and let us know if you want us to consider making this in the future. You can be as specific as you want, or perhaps just a general product category wish, it is completely up to you!
Let's have some fun here. This thread isn't for insulting or bashing current products, or each other's ideas for that matter. It's just a simple thread for "posting" your ideas on what you think, and what product you would like to see us "have a go" at!
Ready...Set...GO!
I think its cuz they screwed up a cable before so they had to modify their port or something. Either way a tighter port is always better then loose ones.DAP version of Diablo 2, with an improved 4.4mm port for smoother insertion/removal. (I feel most 4.4mm ports on your products are tighter than others.)
I loved my minidisc players, shame it was sooo hard to get music on there, stupid Sony.
I honestly loved the mini-disc format!
Cheers!!
