Pharmaboy
Great info. Thanks!• The tube risers (socket savers) also permit better heat dissipation from the tube glass. I would also get them for the 6SN7s: if you roll those, you will be able to grip them by the micanol base rather than by the glass - thereby avoiding detachment from the base.
• Amplified Parts (direct / via Amazon):
So the P-ST9-900's pins fit 12AX7/12AT7/CV533s? (dumb question)
