Hello everyone,
First time poster and new owner of an iBasso DX80!
I’ve been listening to this piece of hardware for a few weeks now, and truly like what I’ve heard so far. The build quality is fantastic and I love the solid buttons.
I’m using some well used Grado SR60’s that I’ve had for years (love these little cans) but am looking to upgrade to possibly some ATH-M50x Professional Monitor Headphones or others but I'm not quite sure what to look for or what works best for the iBasso.
I am using Lurker’s 1.4.2 version and have not tried any other firmware. I’m going to try 1.3.3 due the overwhelming posts referencing it being “better” (which I know is subjective). I am using the default completely flat EQ in the settings. I listen to songs at 70 – 75 or so with low gain. I jump back and forth between low and high.
I consider myself fairly knowledgeable about audio but I am no means an expert and have quite a few questions about this device and its functions that perhaps some of you experts can answer:
1.) Is there a particular reason why the battery drains so quickly? I have set my display brightness to almost the lowest setting, and even on a full charge, with the screen “off” while playing, I can go from 100 to 90 in about 15-20 minutes. Can anything be done to enhance the charge?
2.) What is the difference between high and low gain? I realize one makes it “louder” but the same loudness can be achieved on low gain if one notches the volume past 80 or so.
3.) What does the digital filter do and what difference does it make? I can’t discern any audible difference between the two toggling back and forth.
4.) I’ve noticed while playing some songs, there are “pops” or clicks when playing files, that suddenly don’t appear when playing again. In addition, the song will skip to a strange part of the song when going into the next track. For example, track 1 will be playing, it ends, then jumps to 30 seconds into song 2.
5.) I’ve also noticed that with far shorter tracks (maybe 10 seconds or less) the song doesn’t play fully, it is cut off around 8 seconds while not finishing.
I apologize for so many questions! Overall I am very pleased with my iBasso. I’ve used an older 3rd generation iPod for so many years, the difference is night and day. I figure if I get some better headphones and let the iBasso burn in for a while, it maybe improve some of my issues.
Many thanks and may your ears be full of rich, warm sounds!
