OK - I've only just had a chance to install this.
On the plus side, 'Artist' sort order in the database seems to be fixed (on the assumption you can get a clean scan)
Unfortunately, I can confirm, as reported by others, that the default play order when playing from directory seems to be alphabetic on title, which is obviously an unhelpful default since most albums then play out of sequence without lots of effort. I assume it's using the tag information for this, rather than using any sort of ordering based on filename? Perhaps, if so, it could default to using the track number embedded, taking into account the various standard number schemes?
I've not tested the fileset which caused the database scan to crash previously, but it sounds like it's still crashing out for some people. I think there needs to be a database logging option in advanced settings which logs all the files it doesn't like while scanning to a text file on (say) sd card 1. That way, the scan should complete, and we'd not all be searching for needles in haystacks for the file(s) which are breaking the scan.
I'm going to have to fall back to 1.4.2, since searching by 'Artist' in the database doesn't really work for a large part of my collection, and playing from the directory is currently sorting unhelpfully.
