iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
Aug 14, 2021 at 11:42 AM Post #721 of 5,022
Can a lucky owner of the 300 MAX confirm that it is possible to play Tidal MQA files in full decoding (8x) on the 300 MAX like the regular DX 300?
Thanks.
Playing the same Tidal master, new Tiesto track, DX300 (352.8kHz) vs DX300 MAX (705.6kHz), look in Notification bar. That tells me DX300 MQA 8x while DX300 MQA 16x (getting 705.6kHz playing the same track on R8 which supports MQA 16x).
Aug 14, 2021 at 12:59 PM Post #723 of 5,022
Any current DX300 Max owners happen to have a ZMF can to test it out with?
Aug 14, 2021 at 1:43 PM Post #724 of 5,022
A screen protector for the DX300MAX made of glass decreases the touch sensitivity and does not work well. We provide thin film plastic for this screen. We use a very high quality Sharp screen.
Regarding power, please remember we are using direct battery power/current. There are no step up components used, which are commonly used. With a direct voltage and current, a higher level of sound quality can be obtained, which is one very important reason we use it in the DX300MAX.
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
Aug 14, 2021 at 5:39 PM Post #725 of 5,022
As screen protector most of the time, (not glass though) I either use the Brotector brand (matte) or cut out a piece from a slightly thicker matte iPad protector film. Unfortunately the films provided by all DAP manufacturers are fingerprint magnets.
I didn't have any sensitivity problems (for example, with DX300 or DX220MAX) until now.
Aug 14, 2021 at 6:42 PM Post #727 of 5,022
Oh my.. !!! MAX300 playing LO to C9 playing through Verum 1's...
This is sensational 👏
Aug 14, 2021 at 7:23 PM Post #728 of 5,022
Anyone experiencing crackling or static pops within music tracks?
Aug 14, 2021 at 7:37 PM Post #729 of 5,022
False alarm. A quick reset of the unit and reconnect to the wi-fi has sorted it out. Seems to be an issue with my Internet connection on that occasion. Phew!
Aug 14, 2021 at 7:40 PM Post #730 of 5,022
To be honest... the MAX300 doesn't need the C9. It is very capable on its own and somewhat warmer with exactly the right amount of treble and detail. Bass is thunderous without any booming. Soundstage is massive. Very powerful sounds coming out of this unit. Just as well... MAX300 + C9 = Trolley required.
Aug 14, 2021 at 8:18 PM Post #731 of 5,022
To be honest... the MAX300 doesn't need the C9. It is very capable on its own and somewhat warmer with exactly the right amount of treble and detail. Very powerful sounds coming out of this unit. Just as well... MAX300 + C9 = Trolley required.
Look forward to trying my Max with D8000 Pro and Diana V2 soon. :)
Aug 14, 2021 at 9:11 PM Post #732 of 5,022
Do you think the C9 has greater driving power on its own vs the 300 Max? Would make sense since the former is a dedicated amp but still curious :)
Aug 15, 2021 at 12:54 AM Post #734 of 5,022
I experienced this, especially use the low resistance IEM like my Westone W80. Need to switch off all WiFi and Bluetooth to resolve the issue, or switch to mango OS.
This will be corrected in the next firmware for the DX300MAX.
