jamato8
When you tried to charge it, how long did you leave it on the charger?I guess couple months ago.
I took out the cable to charge my Ti unit downstair during dinner and noticed the problem for SS.
Couple hrs and no red blinking.When you tried to charge it, how long did you leave it on the charger?
Did you check the plug to make sure it is clean, no lint etc., in it.Couple hrs and no red blinking.
Let me charge all night and see again.....
I used that same charger cable to my other Ti unit, and it's charging fine.Check that charger also. No light at all can mean its not even getting power. If you get a light try holding down the power for a few minutes like i did.
It's pretty clean....Did you check the plug to make sure it is clean, no lint etc., in it.
Tried 2 different Analog cables already.As jamato mentioned take a flashlight make sure nothing is blocking the charger port. Strange, if you are getting no light at all its not getting power or a bad battery possibly.
You have any other chargers you can try?
Will check for lint tonight after work.
I have 2 DX300MAX, SS and TiDifferent cables? are you trying a barrel cable attached to a low power USB adapter or a fully connected charger with the barrel connector attached perm? Want to rule out if you have the correct power adapter voltage and amperage etc.
I use my DX300 MAX the most often, and recently the analog section showed 0%, but it went back to the normal amount with no restarts, if I recall correctly.Does anyone has this kind of problem?
SS unit has been power off and set aside for sometimes. Power up last weekend. Analog section shows 0%. Tried to charge but it won't charge.
Red LED is not blinking or On when it suppose to charge.
Power off and on multiple times. Still the same.
Reset and still not able to charge Analog side.
Digital side ok.
Any recommendation?
paul@ibasso.comHi,
Anybody know Paul email?
I need to send in to check and repair.
Still show as 0 for Analog after charging all nighter.
Thanks.
