Your 3Max was improperly reset by the previous owner I think.Trying to install the app is a big circle jerk. I googled it, it said purchase in the Google Play Store. I go there and try to pay the $7.99. It says the google act is not associated with a device. Please access the App Store on your device. I did and nada. I am logged into google and I have payment set up with my account.
iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
- Thread starter Paul - iBasso
Doug2507
It was full factory reset.
I would suggest reinstalling the firmware if you're facing all these google service issues which should not be happening.It was full factory reset.
3Max Ultimate mode + WA8 + IE900 is now my ultimate transportable combo.. and I now have 2 defensive weapons to throw!
Interestingly, line-out drains the amp-side power~ I'd have thought only digital batter would be used hmmm3Max Ultimate mode + WA8 + IE900 is now my ultimate transportable combo.. and I now have 2 defensive weapons to throw!
How does the ESS Dac of the WA8 and the 3max match? Can you avoid using the ESS Dac?Interestingly, line-out drains the amp-side power~ I'd have thought only digital batter would be used hmmm
I'm using line-out (4.4 to 3.5mm), so it completely bypasses the ESS dac.How does the ESS Dac of the WA8 and the 3max match? Can you avoid using the ESS Dac?
ESS sounds so flat compared to the holographic image out of the 3Max. Never liked ESS so I may be biased haha
Thanks. Exactly my point!I'm using line-out (4.4 to 3.5mm), so it completely bypasses the ESS dac.
ken6217
Transportable? On a flat bed truck.3Max Ultimate mode + WA8 + IE900 is now my ultimate transportable combo.. and I now have 2 defensive weapons to throw!
ken6217
Me either.I'm using line-out (4.4 to 3.5mm), so it completely bypasses the ESS dac.
gentzen
Have formatted my Micron to 16MB unit size, down from 32MB, and, after having listened for several hours, I can say that jitter is almost entirely gone. Used to get jitter every few songs on the higher size, now still get at something like a rate of once every fifteen songs, which is significant improvement. Sound has slightly closed, relative to the top size, but that's to be expected, no biggie tho. Still larger, cleaner sound than before (on .5KB). That's with Neutron, I've not tried MangoOs. For info, all my tracks are 11MB or above (up to about 300MB tops), all flacs.
ken6217
I’m sure it was reset correctly by Doug.
ken6217
The ManzierMight need to wear this bra
ken6217
Well it worked. I cleared my history and downloaded the Google play store app. I then was able to purchase UAPP.
I didn’t say TIDAL or Qobuz yet but I’m kind of in a hurry I’ll have to revisit it later this morning. Am I supposed to give access to my system? I was asked that, but didn’t click on it yet.
Total: 9 (members: 0, guests: 9)
