They’re easy to put on the Max, just don’t be dumb like me and put it on with the wrong side. ![Man shrugging: medium skin tone :man_shrugging_tone3: 🤷🏽♂️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f937-1f3fd-2642.png)
I did this and did it in the bathroom after steaming it.I use The trick that is to clean your Max as soon as it is out of the box and under LeD lamp. Use 2 sticky tape on the top and bottom of the protector as your extensions. Peel off the film, slowly align it to place ? It works, but sometimes it doesn’t![]()
Is it easier to apply or easier to be confused ? I am confused !!They’re easy to put on the Max, just don’t be dumb like me and put it on with the wrong side.![]()
I physically shuddered.I like the sandpaper fix. Use a little 320 and pow, no more worries about the screen, you have all the issues done and over with. And, no reason to use a screen protector.
My brother used to say it is so liberating to get your first scratch on your new Vettes, same applies here. I like to keep my stuff as pristine as possible makes it easier to sell.I like the sandpaper fix. Use a little 320 and pow, no more worries about the screen, you have all the issues done and over with. And, no reason to use a screen protector.
I have a tiny rock chip in the paint of my 2020 Supra. No one can see it, but I do. lol But it is done and over with. lol I could fix it easily but why, then I would have to wait all over again for another one. And the windows that Toyota used, soft but I guess for safety reasons. I know guys that get them replaced twice a year due to cracks.My brother used to say it is so liberating to get your first scratch on your new Vettes, same applies here. I like to keep my stuff as pristine as possible makes it easier to sell.
M8 was horrible. Vinyl from the '90s. 3Max comes with a stiff sheet. Drop and watch the bubble go away. Very easy.I am usually reasonably adept at screen protectors, but the one I had for my M8 was dried out and after I finished I couldn't believe how bad the install went. I couldn't have done worse if it was my first install. I was able to get some extras and it looked good. Seeing the failure rate with the 3Max screen protectors increases the choke factor 10 fold.
Vinyl from the 90 is still the very best of it !! AAA all the way!!M8 was horrible. Vinyl from the '90s. 3Max comes with a stiff sheet. Drop and watch the bubble go away. Very easy.
Wrap your car too. There's vinyl for that.I have a tiny rock chip in the paint of my 2020 Supra. No one can see it, but I do. lol But it is done and over with. lol I could fix it easily but why, then I would have to wait all over again for another one. And the windows that Toyota used, soft but I guess for safety reasons. I know guys that get them replaced twice a year due to cracks.
So don't hand your DX out the window when driving. No reason to check the susceptibility of rock chips!
That thing looks glorious. I'm so envious of all your max ownersHad a successful one-n-done application of the 3MAX screen protector. Couldn’t say the same for the DX300, went through both tempered glass and film, LOL, wondering if I could be request replacements from Paul…
Repurposed the Van Nuys C9 case, Max fits perfectly with extra room. Now I can easily transport the 3MAX around the house.
