After I wasted all of my own hybrid glass (and one of my plastic) protectors on DX300, as I've got crab fingers, I had to buy an after-market one to fit . No way, I'd ever leave it like this. As I've said before I'm disciplined, but NOT THAT DISCIPLINED.
iBasso DX300 MAX Dual AK4499 Snapdragon 660 Octa-Core 6GB RAM 128GB ROM NEW Firmware: 2.02Available.
- Thread starter Paul - iBasso
funasianguy4u
I agree, the screen protector situation brought my OCD out, I thought I had it contained - the good news, only one tiny bubble (which I am not able to get rid of), and I feel, I cannot chance a second re-try, I am already so close, I don't feel I can achieve that perfect score, unless ibasso sells like 2 dozen screen protectors in bulk, then I guess it is like a lottery scratch game, and one can attempt ..... .....one screen protector and a goal.....at a time...
- Oct 14, 2013
Lol!!! Thanks for the chuckles mate !! We all feel you about the protector. My dx300 has no protectorI agree, the screen protector situation brought my OCD out, I thought I had it contained - the good news, only one tiny bubble (which I am not able to get rid of), and I feel, I cannot chance a second re-try, I am already so close, I don't feel I can achieve that perfect score, unless ibasso sells like 2 dozen screen protectors in bulk, then I guess it is like a lottery scratch game, and one can attempt ..... .....one screen protector and a goal.....at a time...
I have been forewarned that I am going to be dealing with a screen protector issue on my arriving unit. I think he said I have one to play with....pressure will be on to make it count.
Ahaha you have one chance to fix it!
- Oct 14, 2013
Send it to me, I can apply it and possibly upgrade internal wires too !!!I have been forewarned that I am going to be dealing with a screen protector issue on my arriving unit. I think he said I have one to play with....pressure will be on to make it count.
Infoseeker
Where do I get a replacement screen protector anyways? Already failed twice.
I normally buy a 12" iPad Pro matte film and cut pieces using the original as template. Then you have close to infinite tries.Where do I get a replacement screen protector anyways? Already failed twice.
- Oct 14, 2013
I use The trick that is to clean your Max as soon as it is out of the box and under LeD lamp. Use 2 sticky tape on the top and bottom of the protector as your extensions. Peel off the film, slowly align it to place ? It works, but sometimes it doesn’t
Death_Block
I choked on my coffee.... hahahaIt works, but sometimes it doesn’t
jamato8
My screen looks perfect, no bubbles, no misalignment, just right. Oh, I don't use a screen thingy.
- Oct 14, 2013
LOL!!! No protector ? Right on!! It also feels much more authentic than having a protector on itMy screen looks perfect, no bubbles, no misalignment, just right. Oh, I don't use a screen thingy.
I am usually reasonably adept at screen protectors, but the one I had for my M8 was dried out and after I finished I couldn't believe how bad the install went. I couldn't have done worse if it was my first install. I was able to get some extras and it looked good. Seeing the failure rate with the 3Max screen protectors increases the choke factor 10 fold.
