- Oct 14, 2013
I have not tested Wifi performances on MAX. Have anyone tried it and hear noises ? At least while I was tinkering within AndroidOS and playing offline library With WiFi on , I have not observed noises
I have listened with the screen on or off and don't hear a difference in noise floor and if the screen is off, why would you need shielding, it is off.One thing I am surprised about is the lack of proper shielding of the screen. I am not sure if it has anything to do with the already very very bad WIFI performance. Otherwise I cannot believe a company creating such a product not shielding one of the noisiest of the components. Or is the screen as one piece has a shielding layer that guarantees manufacturers interference free operation.
Thanks for sharing Vince. May you keep posting about your experience with connectivity?I have not tested Wifi performances on MAX. Have anyone tried it and hear noises ? At least while I was tinkering within AndroidOS and playing offline library With WiFi on , I have not observed noises
It outputs 18 volts? I didn't read that.
Stay updated on iBasso at their sponsor profile on Head-Fi.
I see, so this usb C cables has the circuitry in the usb C end to generate 18V that is compatible to PD 2.0 standard ? That is a good one, I will grab oneThe adapter is a PD 45W. As part of the PD spec it can be configured from 5 to 20v by the device plugged in (here the PD is emulated in the USB-C end of the cable)
Thanks. I found equivalent on Amazon here in the US and ordered. I have a PD but it is single output so got a 90watt with duel output so will be able to do the 18 volt and the 5 volt to the DAC section. Not cheap but an all in one solution. Like my 2020 Supra, it cost enough but there are add on items I have gotten that make it an even better sports car.I ordered these two yesterday for the MAX. Should mean only one charger required.
PD and USB QC3.0 plus PD to 18v cable.
https://www.amazon.co.uk/dp/B07YHPY4RL/ref=cm_sw_r_other_apa_i_pDL5EbFWDAWKP
https://www.amazon.co.uk/dp/B07XD7J1HB/ref=cm_sw_r_other_apa_i_QCL5Eb0MVYNHS
Will let you know.
I have a very good experience with this one:I see, so this usb C cables has the circuitry in the usb C end to generate 18V that is compatible to PD 2.0 standard ? That is a good one, I will grab one
CERRXIAN 4.9ft 65W PD USB Type C Male Input to 5.5mm x 2.1mm Power Charging Cable for Laptop (5521)
$11.99
Onite 20AWG USB to DC 5.5x2.1mm Barrel Jack Center Pin Positive Power Cable Charger Cord for LED Strip, 3.3ft, 2-Pack
$5.78
USB C Charger, RAVPower 90W 2-Port Wall Charger PD 3.0 GaN Tech Type C Fast Charging Adapter Compatible with MacBook Pro Air, iPad Pro, iPhone 11 Pro Max XR XS X SE2, Galaxy S9 S8, Nintendo and More
Sold by: Sunvalley Brands
$54.99
It supposed to do up to 20 volts and got two different cable types, so I shall see. :^)Please, do tell us when you get it if that RAVPower charger works with MAX. Curious about it as well.
