mikejazz
- Jul 8, 2001
Ok--did it. No change.I bought a usbc to usb c cable. It's the only one I have. Is there a special cable I should be using?
C to C cable can be tricky between two devices that both support OTG. It may work only when the cable ends are connected in a particular order, or doesn't work at all. If you have a USB hub, you can start with connecting the hub to the phone, then DX220Max already in DAC mode to the hub via A to C cable.I bought a usbc to usb c cable
I agreed, this is a better way to use Max as external DAC. The USB C is very funky and complicated interfacesThis is how I got DAC mode working too. I initially ran a usb-c>usb-c between my iPad Pro and DX220 Max, but it didn’t work.
I later tried an old usb-c to usb-a “pigtail” from iPad then the usb-a to usb-c cable (the one that came with the Max) plugged into the “pigtail” and it works perfect.
Similar situation with my iMac. Usb-c>usb-c cable didn’t work for dac mode, but usb-a to usb-c works perfect.
The Digital section, is just that, all that is digital and the conversion to analog. It of course need a source of power and for the Max, there is a single battery just for this section. Then there is the amplifier, all discrete with the Max, and for that, you get 4 batteries with no boost to the voltage. Most amps in daps if the voltage swing is going to be higher, use a single battery and then a chip that boosts the voltage to what is desired. This works and can work well but optimal is pure voltage and current from a battery etc. but due to size, this is hard if you are going to have any play time. So the Max uses the 4 batteries and you get non boosted pure voltage and current. By dividing the batteries between the Dac and the Amp, you also don't get any digital info (many different types) creeping into the analog amplifier section. This also means a better current delivery to each section for a purer sound and most likely, more of what the dac manufacture had in mind. And, the Max does this. Best sounding dap I have ever heard, easily.I'm considering the DX220 max for my next DAP, but I'm confused about the separate digital and analog sections and their respective batteries. Can someone give me a dumbed down explanation?
It is always using all the batteries unless you are using digital out, then the digital section is using the battery that is isolated from the other 4 batteries. I like the Max as a complete unit, using the headphone out and it is extremely quiet so it is also good with IEMs.That's a great explanation, thank you.
So if I'm just listening to the headphone out, it's using both sections/battery configurations correct? What are the use cases for using one over the other?
