DaYooper
Can that equipment actually sound better than the DX220 max anyway?
Use uapp. It will let you choose the app when playing dac ampI’m trying to play through JDS lLab Element II and want to steam from Qobuz. Except, only Mango will play to the app.
The heat makes me bit worried so I strip the MAX naked and I put it on a room with AC (I live in tropical climate) to reduce excessive heat from the device.
I have started a thread for the SR2 for Headphones but nothing yet for specs.Yes, works like a charm, though I gotta admit, lately I have been enjoying a lot the "analog" control of twisting the volume knob Just sit down, relax, and enjoy! And, now more reason to enjoy listening at home since I starting to test iBasso SR2 open back headphones.
Stay updated on iBasso at their sponsor profile on Head-Fi.
The Amp section requires 12 to 18 volts. So you need a PD charger, not a computer. I use a PD charger and a cable that is for 15 volts so that the PD charger doesn't put out the full 20 volts to the amp section battery.Any chance to recharge the amp section through standard usb charger or directly trought usb of the PC? So I suppose the existence of a cable it has one side usb and the other side the dc-in.
I believe it would be very confortable if you forget the wall charger included or if you want to travel lighter.
