iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
Jul 25, 2020 at 12:24 AM Post #2,266 of 3,626
Updated:
Ok. I tried a few more things today. I tried the FiiO app without success.
Back to the Hibymusic app.
8Bowv2n2zRaul6_qHncInbQYxxJya4JhrVJdpGGqDaguI7cz7bcw4uIJ23PWOI8
I had trouble linking over Bluetooth which i require for in the go and commuting if i take the Max.
My music is fairly tightly curated so not much fast forwarding needed generally.
5gRQ2SOPezDNLH1xJ3t0ImIyJmyckJ0np-JSscb9Vpa7tHiG0aorxIbXwqFk8Do
Paired with the iphone. Bluetooth and wifi.
bgqtTrTXgDH-kxu4ouE68wvH3tJawRDGxXwWDHolySpFBDPus3-OcBhNR91hLEI
Used as a fast forward/ play and pause/ rewind remote.
Iphone SE above and Max below.
LiO0VtejX37h6W6l0FV6iboK7BTFxfZhakQo3Ga9uIsop3mgffI0nwbCpT0B2bM
You can navigate through and choose music.
v3uFdic4aCd5ZeD7GdBo7gNAF7WHiBoNWENsdOKxlBe5XmdnBMiMvn7X6uyl-Rw
R9JOJSg8iXirkY-3K2BVmXT57ojzCCMAfOZFam78JTrK9G_28PGj1Fz1DehbcZ0
Question: @artpiggo were you able to get it working purely over bluetooth only?
I am not sure. My friend borrow the unit during weekend so I will ask him to try that. May delayed answer.
Jul 25, 2020 at 1:00 AM Post #2,267 of 3,626
If other Max owners could do a few tests with their different phones - we might come up with a collective solution.
i would prefer a cellphone on the go solution (BT) rather than having to carry an extra BT ‘button’.
at present i can control the max from afar at home using this method when its feeding my home system. Progress.
Lil’ help please :)
Jul 25, 2020 at 7:57 AM Post #2,268 of 3,626
Lil’ help please :)
Does using all wireless features drain Down your batteries faster ?
Jul 25, 2020 at 9:05 AM Post #2,269 of 3,626
Just got my MAX, everything went fine, installing Play Store is pretty straight forward, playing music from local file and streaming Qobuz with UAPP with no problem at all, still on stock fw.
First impression is very good, compare to N6ii with E01 amp module MAX made Noble Sultan faster, leaner, detail yet smooth, soundstage is wider.
I got question though is OTA fw update not available yet? MAX says there's no update available.
Jul 25, 2020 at 9:07 AM Post #2,270 of 3,626
Need to download and put in storage for update locally.
Jul 25, 2020 at 9:33 AM Post #2,271 of 3,626
So no OTA service at the moment, have to update locally.
Thanks for your respond.
Jul 25, 2020 at 9:42 AM Post #2,272 of 3,626
Dunno
if i was doing it this way i would be at home near power plugs - using the home system. No probs
Need a BT solution for on the go
probably have to pick up a remote button...
EDIT: meh ordered a remote button :)
Jul 25, 2020 at 4:02 PM Post #2,275 of 3,626
Dunno
Which one have you selected? I’ve seen two models here in thread but can’t get what is a difference between.
Jul 25, 2020 at 6:42 PM Post #2,276 of 3,626
i went for the one @twister6 said worked.
about $30 - $40. There were cheaper options but the reviews were mixed. I figure buy once, buy right. (It goes by another name too - but i cant find the post @twister6 ).
-Should arrive in a few days or so.
54E46F4B-61FD-421E-8905-428F52C4C252.jpegC3285EED-8EC9-4685-B4F6-78D788662F10.jpeg00AF7CD1-F182-48A1-9E64-A985BCDF88A3.jpeg
Jul 26, 2020 at 12:47 AM Post #2,279 of 3,626
Picked up this one, works well after the recent update.
The circle button turns the screen on and works as a home button. Volume buttons work only with the DAC volume.
Just curious, does the circle button also bypass the lock screen? Does the mute button work as well?
Thanks
