iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
Jul 22, 2020 at 10:45 PM Post #2,251 of 3,626
I use hiby music app to control music from smartphone. That's easy enough for me.
hmm - i went through many remote apps today (iOS) trying to find one that worked.(No luck)
Does the Hiby app require me to use the Hiby player on the Max?
(Probably)
and are there any significant sound signature changes between iBasso Mango and Hiby app if so.
thank you in advance.
Jul 22, 2020 at 11:04 PM Post #2,252 of 3,626
(Probably)
Yes it needs to be Hiby App in both DX and smartphone (android in my case). I don't think I hear any sound sig change.
Jul 22, 2020 at 11:45 PM Post #2,255 of 3,626
@Paul - iBasso, is there MQA support for Mango OS? I can see MQA in the Android Mango Player but not the OS player.
Jul 23, 2020 at 12:34 AM Post #2,256 of 3,626
thanks - i will give it a look.
Much appreciated.
my library is small and fairly well curated - so not much skipping when shuffling
but it would be nice at times
@twister6 @Whitigir any thoughts on hibyplayer versus Mango android?
- mainly just 16/41 for shuffle times
Jul 23, 2020 at 5:30 AM Post #2,258 of 3,626
Is there any 3rd party case for MAX?
Jul 23, 2020 at 7:20 AM Post #2,259 of 3,626
Great idea!!! Thanks a lot. I'm trying this tonight.
Jul 23, 2020 at 8:55 AM Post #2,260 of 3,626
We recently tried to measure the maximum power , and maximum AC voltage that 220 MAX can produce, In the range of popular resistances from 8 to 40 Ohm.
It turned out that the maximum AC voltage level on the Phone out was 1.47 volts, and on the balanced output 2.84 volts / 40 ohm.
The question , how exactly were the voltage values of 8 volts obtained? This is much more than 3 volts that we get even without load... Perhaps there are some limits or software level settings? How do we get the loudness limits correctly?
Jul 23, 2020 at 10:44 AM Post #2,261 of 3,626
Jul 23, 2020 at 10:47 AM Post #2,262 of 3,626
Much appreciated.
Unfortunately I am a huge fan of MangoOS first. Then secondary the Neutron player. I have yet to bother with others for a while
Jul 23, 2020 at 8:30 PM Post #2,264 of 3,626
IBasso DX220 Max Remote Using Hibymusic App
Thanks to Head-fier @artpiggo for PM’ing me and helping me get it working.
XTBzsk_DCukc7YYLgrkw8UbcBCKGFG7oFAZN_N3JwU0zz4daQ-lOELmtLPdlwFI
The iBasso DX220 Max does not have any physical buttons.
Some have found other physical remotes work (especially after the recent update).
Such as the Satechii:
4J095IR698SPpudkNh25cxa-6swgSsZa3hlRhwShGSufCDaRJf1Ri1eKluX1uD0
And a few other similar ones (good for driving cars safely etc).
Many of us might be browsing our phones on a commute etc and via phone is useful.
EDIT: i do not know if this first effort by me was done over bluetooth or my homes wifi...ugh.
Enter the Hibymusic app.
(I don’t know any music playback quality versus stock iBasso Android Mango OS).
Directions:
p84xTejI_OXoGboBVCukgBrFG_Gl4WPJSWSj1Z9bC2bUV7ewIp5T37Y_tPyQ_jI
“DX220 MAX open BT.
Open the HibyMusic app and set it as hiby link server.
(NOT Hibylink client).
Open phone in the Hibymusic app
-and set it as hiby link client.
Open Bluetooth and click to pair with DX220MAX.” - Artpiggo
NOTE: for several tries i had not luck with the DX220 Max showing up on my iphone.
- i then paired the FiiO BTR3K to open a pathway so to speak and then the iBasso DX220 Max connected.
BOOM! A remote for the DX220 Max.
NOTE: it can be hit or miss depending on your mobile device for connecting. I had some difficulties (hit and miss for me using iphone SE) - others were ok.
Give it a try :)
cDitFUgup15H9Z5DFWSqhTvbBEw9YFRHCo3CTg7VV7Eq7y66RyzZuOUzCQ_ba_o
ZCQqTZsc8z0qXmS053bUWhzZsWFzkNOlyKFLqtMEYXH-NcBPi_sZ6XsHRhwXiKA
1534dVebihdo4-daEIozbpVgN6kl7Zz-seFL078HPZaU_1_KmrNpXetVjUmE3Jo
Jul 25, 2020 at 12:14 AM Post #2,265 of 3,626
Directions:
“DX220 MAX open BT.
Give it a try :)
Updated:
Ok. I tried a few more things today. I tried the FiiO app without success.
Back to the Hibymusic app.
8Bowv2n2zRaul6_qHncInbQYxxJya4JhrVJdpGGqDaguI7cz7bcw4uIJ23PWOI8
I had trouble linking over Bluetooth which i require for in the go and commuting if i take the Max.
My music is fairly tightly curated so not much fast forwarding needed generally.
5gRQ2SOPezDNLH1xJ3t0ImIyJmyckJ0np-JSscb9Vpa7tHiG0aorxIbXwqFk8Do
Paired with the iphone. Bluetooth and wifi.
bgqtTrTXgDH-kxu4ouE68wvH3tJawRDGxXwWDHolySpFBDPus3-OcBhNR91hLEI
Used as a fast forward/ play and pause/ rewind remote.
Iphone SE above and Max below.
LiO0VtejX37h6W6l0FV6iboK7BTFxfZhakQo3Ga9uIsop3mgffI0nwbCpT0B2bM
You can navigate through and choose music.
v3uFdic4aCd5ZeD7GdBo7gNAF7WHiBoNWENsdOKxlBe5XmdnBMiMvn7X6uyl-Rw
R9JOJSg8iXirkY-3K2BVmXT57ojzCCMAfOZFam78JTrK9G_28PGj1Fz1DehbcZ0
Question: @artpiggo were you able to get it working purely over bluetooth only?
