Just got my personalized DX220 MAX unit to review and a pair of IT00's along with it!
Fantastic!
Fantastic!
Do you ship it back after the review ?Just got my personalized DX220 MAX unit to review and a pair of IT00's along with it!
Fantastic!
But it has your name on it ?It goes to someone else from what I understand.
hi Nayparm,
i have little to no experience with electronics, but do you have to get the cable and the little usb dongle thingy to program it or the cable will work on it’s own? Thanks.
I also bought a few cables from Witrn (just arrived today, coincidentally). Their PDC003 series has fixed 9V/12V/15V/20V varieties and all you need to do is use that fixed 15V cable and make sure your charger supports 15V via USB PD (otherwise the next highest voltage would be used: ex) a charger only supports 20/9/5V profiles and you use a 15V cable, you will see 9V with that cable).
I’ll also post some measurements with the 15V cable soon.
Strange!! Mine is upped by HQPlayerPro, and Android Mango is fine but not MangoOSI'm listening to DSD512 music in Mango OS right now. These are upconverted files using XiSRC program.
Vince, can you try exactly the same files on you DX220?Strange!! Mine is upped by HQPlayerPro, and Android Mango is fine but not MangoOS
