Has any of you also has the quirk that when you turn up the volume from zero, first the right channel is audible and then I continue turning up the left channel becomes audible and catches up? Actually the right channel never really completely becomes inaudible for me. When I turn the volume all the way down, it is still veeeery tiny bit audible.
iBasso DX220Max ****************** New FW! 1.01 for download! 1st Page.
- Thread starter Paul - iBasso
Shawnb
- Dec 2, 2012
Yeah I notice the right channel is a little stronger then the left. I thought I was imagining it
And how is it for you when turning up the volume from zero? Do you have the same thing, first hearing the right channel and then the left? At the listening volumes I think mine is OK (I also had it checked from my wife), but initially at the very low volumes the difference is pretty audible.
I called AudioHeaven (where I bought it) and they said that it happens with analog volume controls sometimes.
purk
- Sep 26, 2001
That’s normal especially on the lower volume range. I hope the volume control used in the Max is high quality and will last us a long time. I wish there is a tiny DAC-T that would fit in there.I called AudioHeaven (where I bought it) and they said that it happens with analog volume controls sometimes.
jamato8
As purk says, it is normal and typical. I have some very expensive pots that do it in the very low range, it isn't any big deal. Also you can turn the volume control back and forth a number of times but it really isn't any issue.And how is it for you when turning up the volume from zero? Do you have the same thing, first hearing the right channel and then the left? At the listening volumes I think mine is OK (I also had it checked from my wife), but initially at the very low volumes the difference is pretty audible.
Anyone try LCD 4Z with this?
I wish iBasso would invest the time to make a proper menu implementation, by removing the items that don't make sense at all and adding shortcuts that makes sense.
Out: Auto rotate, Aeroplane mode, Do not disturb, Location, Hotspot etc.
In: Gain, USB DAC Mode, BT DAC Mode, Filters etc.
Why after several years of working with the same software platform, is it so difficult to implement a simple menu properly?
Infoseeker
Airplane mode I'd keep, it resets some settings sometimes without needing to clear the cache.
Hmmm...resets some settings sometimes without needing to clear the cache? Which settings? Frankly that kind of a "hidden feature" does not sound right to me.
For those that have heard the MAX and the M15... what are the differences? Is the bass deeper and in general a messier sound than the M15??
ALSO
any comparisons to Hugo 2?
ALSO
Checked again using this piece which has kind of an overwhelming bass with A18t and but very clean balanced bass with Focal Stellia. I think MAX has a bit cleaner bass and a more around your head feeling. M15 is a tiny bit more front of you.
Thanks for the feedback! Really great.
i have m15 now... been comparing to mojopoly. Seems more dynamic.
have lcd4z coming this week.... with Hugo tt2+mscaler the 4z has a rich meaty sound... I’m wondering if I can get this with m15 or the max.
will try with m15 later this week. May need to order a max to try.
Good point. MAX sounds also more dynamic compared to M15. M15 sounds a bit flatter, though it is a great sounding DAP.
Total: 7 (members: 0, guests: 7)
