newtophones07
9200 , can change ear pads to give a big round earpad.
Can you link to the larger 9200 ear pads? Thanks
And the album of Alain Perez (he was the bass player of Paco de Lucia, I didn't know that he was such an excellent musician even beyond that. I am not really a salsa person, but he is just excellent).
mine arrived this morning and the Italian distributor still has more than one ...For guys in Europe, is the DX220Max still available?
Also, anybody used Verite Closed with it? Thinking of getting this combo, so any impression will be great!
Th900 pads or Dekoni pads.Can you link to the larger 9200 ear pads? Thanks
Thanks for introducing me to this album, and artist, it is fantastic!
You meant the Amp charger ? Yes, it gets hot. It charges faster and also take in higher voltage than the DAC. It also has the thermal putty from it main chips and related components toward the chassis to help dissipate the heatsSo how hot are you guys finding it getting with the DC charger plugged in? Mine seems to get really hot, way hotter then the DX220 ever did.Only gets that hot when that charger is plugged in otherwise it's just warm.
This normal?
The main unit charges just as similar to the dx220
Limited Baby!Ok Thanks. Yeah it gets warm more like a desktop amp, just wanted to be sure it was normal. I'm going to baby this thing for a long time.
I don't understand. So you have an adapter that gets the 20 volts from the PD reduced to near 18 volts?Finally I get something close to 18V (20V supplied by USB PD).
Making sure I’m seeing 20V here:
This is what I see after plugging in the adapter:
What I see from the stock charger:
Okay looks like I’m good to go now. This Energiemax Type C to DC adaptor seems to require a 75W charger so I also got one from them. I tried to use a 45W USB PD charger and that couldn’t even activate the adapter.
I have made a Y splitter to charge DAC and Amp units in 1 wire. Then run it straight from a LPSU (Linear Power Supply Unit) 12V. The DAC only charges slowly with the 12V though
Strangely, the LPSU when compared to stock one has no noises When charge and listen together. I am not sure why but that is that
I am going to buy the IFI charger 15V to use at the office and have this Y splitter carried with me. Will see how it goes
