gto88
- Dec 11, 2014
Yes, of course, and until the comparison comes out.if I were you I just wait for DX220 Max.
AMP8 is 6.2 volts and does 1.2 watts into 32 ohms.2W into 32Ohm is 8Vrms - less than Amp8 isn't it?
... Can't be too hard to put 1tb on board and a couple slots can it?
Sitting here and waiting for Dx220Max
I have DX228EX and I have DMP-Z1, and I can’t hold my breath waiting for DX220Max ....lolcould it be a DMP-Z1 competitor ?
Will the stock amp be in alignment (or an improvement) with the Amp8 EX available in the Group Buy? I plan to buy the Max when it is released, but I don't want to spend for the extra amp if it is redundant.
I know most people don't care, but since there a few testers abroad, what processor is being used? I really don't what to spend $2,000 for the same chip inside the 200/220/160.
Buy a USB HDD and connect it via OTG. Any iBasso DAP I tried works with my WD My Passport HDDs in 2-4TB range. I see no reason why it shouldn't work with WD My Book 10TB as well, which you can grab now for less than $200.2 slots and a 1 Tb version will be great
