iBasso DX200 Firmware Modification Project
- Thread starter WindowsX
- Status
- Not open for further replies.
camillem
- Apr 6, 2017
if we use MangoPlayer android app, Poweramp or Apollo - Fidelity Edition without any app effects, will the sound quality be the same ?
do they all use the same hardware path to play music ?
camillem
- Apr 6, 2017
Hi, i have just installed the free version, you might want to inform people that it's normal if the dx200 stays on logo for more than 2 min at first start so that they are not afraid something went wrong.
For only first time boot up. Next time will be normal.
camillem
- Apr 6, 2017
Yes i know but i might be good to inform people about it. The first time it happens you ask yourself if the device is stucked.
Easy check is if you change songs from 44.Hz to 96hz or vice versa, there is popping sound that means it uses hw perfectly.
camillem
- Apr 6, 2017
i have noticed that poweramp volume is a lot lower than appolo.
If i apply some preamp in poweramp will i get the same quality as appolo ?(yes i know i can try by myself, but i don't trust completly in my earing faculties and would like to get somebody else opinion)
poweramp ui is a lot better so i prefer using it if the quality is the same.
After I try poweramp isn't hw perfect. Only stock app and apollo are working.
camillem
- Apr 6, 2017
indeed this is what i thought too
any hope this could be fixed ?
camillem
- Apr 6, 2017
With public firmware It's still not possible to disable lockscreen. Will this be fixed ? Especially if we use apollo, the lockscreen still shows stock app widget...
(EDIT) after reboot it's working fine now
camillem
- Apr 6, 2017
I have an issue with appolo: it doesn't recognize artists, alls my songs have "<unknown>" artist
camillem
- Apr 6, 2017
The included version of Apollo is v1.1.
V1.4 is available, is it possible to include this version in your next build ?
what is the advantage of using Apollo instead of Mango player?
camillem
- Apr 6, 2017
a far better UI.
Search feature.
Search feature.
Since the latest Purist ROM update my DX200 seems to restart randomly.. happening to anyone else?
- Status
