Firmware: any
Bug Found in: Android Mode / Mango Mode / Both
Issue Description:
1) Randam no sound when playing songs, not frequent but annoying
2) In shuffle play mode, after played dsf file. Mango player will stop. Will resume if pressed power button to turn on the screen.
Firmware: any
Issue Description:
It happened in both Android and Mango mode. It stop in the middle of playing song. Just realize there is new firmware 2.0.78. Will install it and try for a few days see if it will happen again.
My new iBasso DX200 seems to not be able to play via bluetooth be it 16bit or 24bit audio. The Mango player kept on crashing. Bummer. I've already updated to the latest FW. Advise? Thanks.
Firmware: 2.0.78 beta Bug Found in: Android Mode Issue Description: Artist -> Album -> Play (from the beginning) results in the first song being played correctly but subsequent songs being played out of order. Initially I thought it was alphabetical but now I don't believe it is as I've experienced this where the order isn't by track number in tag, or by track name in tag, nor by file name. Track order displayed in GUI doesn't match order as defined by tags.Similar to searching issue described previously.
Firmware: any Bug Found in: Android Mode Issue Description: random pause of the track somewhere in the middle (in 2 days of constant use it happened 4 times).
a.) 1 second silent before the songs starts on Mango (both Androind and Mango OS)
- this results in missing the first second and the last second of the song.
-current song to next song will have a gap of silence in it cutting 1 second outro and 1 second intro
b.) lockscreen displays Mango while using Spotify, (Mango is off)
c.) sometimes Spotify Album Artwork displays in Lockscreen,
d.) Spotify does not open after the recent 2.07.78 upgrade, resulting to hard reset, reinstalling Spotify and redownloading tracks
EDIT: Just now, my DX200 restarted and when I open spotify it was logged out.
When I logged in the downloaded files were not present on the app but still present on the card.
I end up hard resetting again!!
Firmware: 2.0.78 beta Bug Found in: Mango Mode Issue Description:
a. ) Volume always resets to minimum while using directory view mode.
Suggestions to Paul:
a.) additional Battery display while in locksreen will help a lot for quick viewing
b.) Double tap function to disable and enable display (like in LG Android Phones)
c.) Faster navigation of Mango OS will be great too
d.) Title of Song in Mango OS to be displayed without additional tapping will be cool too.
e.) instead of "SEE YOU" at turning off, "SHUTTING DOWN" would be more appropriate. (just minor cosmetic suggestion)
------------------------------------------------------------------------------------------------------------------------------------------- Bug Report Format
Firmware: 2.0.78 beta Bug Found in: Mango Mode Issue Description: Unable to use "Card Reader" undo Mango mode. It is not recognized by Android File Transfer.
Hi, also confirmed this problem, there is no way to read the memory card in mango
I have tried reinstalling drivers on windows and nothing. Mac doesn't recognize it with third-party applications
