ron2ron
Does the heat, actually, depend on battery level: less level - more heat?
I noticed the heating issue at 30% battery level
Then it is normal: to supply the same power, the less voltage - the more current. The current produces the heat.I noticed the heating issue at 30% battery level
I also noticed high temperature under 30%. I had not associated it with the battery percentage before. If I have noticed it quite warm in normal use. I hope it improves with some new firmware.I noticed the heating issue at 30% battery level
Stay updated on iBasso at their sponsor profile on Head-Fi.
Hi all.
I`m using Lurker`s firmware v2.11.293.
How to enter Pure Mango OS? Pressing power button gives me option to shutdown and reboot only.
Where I can find SuperSU app?
Thanks!
I can enter Pure Mango OS on mine - Same FW but mine says - V2.11.293-L0
Make sure you have actually flashed the right FW and it has actually worked!
Yes, that`s the version I have - V2.11.293-L0
I have used DX150FirmwareV2.11.293-L0.zip file
No errors during update.
Im pretty sure you need to unzip the file to get the .img file and then using the latest dx200 android tool fllash that .img file
I did all that
Do I need to use DX150FirmwareV2.11.293-L0-fullflash.zip instead?
Im tying to remember exactly what i did last time but Yes! I think it is the fullflash that you need - good luck
It looks I have messed up firmware and firmware addon
I was using DX150-OTA_1.03.036 firmware with DX150-A8.1-L1.17 addon.
Now I`m trying to flash DX150FirmwareV2.11.293-L0.
FactoryTool goes on loop with update. Screen is not going on.
Any ideas? Thanks!
Ps there is more info on this previously posted in this thread
