iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
Discussion in 'Portable Source Gear' started by Paul - iBasso, Mar 9, 2018.
166 167 168 169 170 171 172 173 174 175
177 178 179 180 181 182 183 184 185 186
  1. quisxx
  2. leo5111
    does amp 6 sound any better using balanced out? which amp has more power then amp 6 and will work with that cable?
  3. Bookbear
    I think it does, but by a small margin. To me, it IS audible, but the difference is nothing like an order of magnitude.
  4. leo5111
    is there a amp more powerful then amp6 that sounds like amp6?
  5. jon parker
    Ive heard great things about the Amp 7 but Im reticent to spend MORE money on what should have been a Great sounding DAP to begin with !
    Its frustrating to have already upgraded from the less than ideal Amp the 150 was shipped with to then find they have made another amp that is even better :/
    Not sure if the Amp 7 is a whopping £160 'better' ??
  6. AGranada
    When I turn on the DX150, nothing is automatically started. I decide if I use Mango or Neutron.
    You can always force Mango to stop and then disable it (settings - apps and notifications - apps information - MangoPlayer). I guess that should not start automatically with that.
    If you delete it, I do not know how you could use it as a DAC on the PC.
  7. leo5111
    unless im reading it wrong amp6 balanced out is allmost double the power output vs unbalanced?
  8. Bookbear
    After 'Force Stop', the option to 'Disable' is there, but it is grayed out... pressing that does nothing. Even after a forced stop, when you leave 'Settings', the Mango player screen is still overlayed on my android home screen, showing the last album played (though it is no longer actually playing). When I turn off the unit and then turn it back on later, Mango is once again active and playing.
    :slight_frown:
    This isn't crippling, but it IS an annoyance. There must be some reason 'Disable' is always grayed out, which is why I am hesitant to try to remove it.
    Thanks
  9. AGranada
    You're right, I stopped MangoPlayer and the "Disable" option remains gray. What version of android are you using? I updated it to 8.1. Maybe you're using an earlier version? I do not understand why you MangoPlayer starts to replay instantly.
  10. Bookbear
    I'm on 8.1 here. Everything else seems to work as it should.
  11. leo5111
    is there a way to go from the balanced out to a portable headphone amp such as the cayin c5 or does that not work?
  12. leo5111
    how is the sound line out of amp 6 vs amp 3? also the power numbers look like amp 3 is like double that of amp 6? amp 6 says 2.4Vrms amp 3 says 6Vrms?
  13. equalspeace
    This player has a damn precise EQ, and the filters are really implemented well.
  14. ron2ron
    Anyone here experiencing DX150 heating up fast after using it for an hour? Is it normal? Thanks
  15. Lurker0
    Does the heat, actually, depend on battery level: less level - more heat?
