Just a heads up: new firmware for the DX150 (Android 8.1), V1.03.036.
http://ibasso.com/down.php
Improvements with this firmware:
1. Rectified the bug that the device name is displayed as DX200 in some areas.
2. Rectified the bug that the first time a 24/96 or 24/192 music file is played after boot up, the play speed is incorrect.
3. Rectified the bug that when 24/48 was output via SPDIF, the play speed was doubled.
4. Rectified the bug that there is a small possibility that the battery can't be fully charged.
5. Option to format the SD card as internal memory has been deleted. (Android OS)
6. Now allows volume adjustment when the screen is off while in USB-DAC mode. (Android OS)
7. Rectified the bug that there is a chance that the play speed is doubled when used with a Bluetooth device. (Android OS)
8. Rectified the bug that there is a small possibility that the thumbnail album artwork under Album view was not displayed. (Android OS)
Instruction For Firmware update:
1. Copy and paste the DX150-OTA_V1.03.036.zip to your SD card's root folder.
2. Go to Android OS, press Settings-->System-->Updater-->local update-->SD Card and tap the zip file.
3. The whole update will take about 10 minutes. Reboot the DX150 after update completed.
