Again add-on, again hard reset, and again no hiby? xD There is no other way? Or apk file to this apps build? Why this app not showing up in first place? Should be fine from what i read in this topic. Or maybe this is bug and i need to start from scratch? -.-I think installing again lurkers add on will restore the custom hiby
iBasso DX150. Dual dacs and interchangeable AMPs. **NEW Firmware that supports AMP9! ** New FIRMWARE 1.05 Dec 30.
- Thread starter Paul - iBasso
Lurker0
Just don't hard reset after add-on. I allow users to uninstall this Hiby build, if they don't need it, and, as such, it does not survive hard reset.Again add-on, again hard reset, and again no hiby?
Ok, thanks i'll try. I am little worried because before hard reset whole system worked very slow and with lags.Just don't hard reset after add-on. I allow users to uninstall this Hiby build, if they don't need it, and, as such, it does not survive hard reset.
edit: So far so good. Hibymusic is here and system works nice. Later i'll check Tidal. Thanks again for tips.
@Lurker0 : Keep up the great work!
NiVrA
- Apr 15, 2017
Hows your standby time guys?
Ok yesterday i checked Tidal. App works fine but one big problem still remains (i hoped that hard reset fixd it) very weak network... Range is perfect as always because my router is in the same room. Is there some way to fix this problem? I mean i have to long wait to start song and than when is ready (buffer done) i playin it 15-20secs and its start to stutter or stop and again loading. I cant listen Tidal normally. In cellphone everything work perfect but DX150 seems to have big problem... Why? In router i only have option 2,4ghz for wifi...
Paul - iBasso
Sponsor: iBasso
Are you getting good reception with the bar indicator? I am afraid that 5 ghz is recommended and works much better than 2.4 ghz.Ok yesterday i checked Tidal. App works fine but one big problem still remains (i hoped that hard reset fixd it) very weak network... Range is perfect as always because my router is in the same room. Is there some way to fix this problem? I mean i have to long wait to start song and than when is ready (buffer done) i playin it 15-20secs and its start to stutter or stop and again loading. I cant listen Tidal normally. In cellphone everything work perfect but DX150 seems to have big problem... Why? In router i only have option 2,4ghz for wifi...
Stay updated on iBasso at their sponsor profile on Head-Fi.
Yes, everything seems to be ok according to DX150, bar indicator is between 75-100%. So no Tidal on my DX150? (( Cayin N5ii worked great with Tidal.Are you getting good reception with the bar indicator? I am afraid that 5 ghz is recommended and works much better than 2.4 ghz.
Edit: there is something really wrong with wifi in my dx150. Wifi analyzer app showing me network speed ~72mb/s for 2 second and than drop down to ~300kb/s or even lower... Like there is something blocking wifi in my ibasso... Maybe soft is buged? Maybe i should downgrade to android 6 and it will help? What do you guys think?
skingg
- Nov 24, 2013
When you try to shake your DX150, do you hear any rattling noise?Yes, everything seems to be ok according to DX150, bar indicator is between 75-100%. So no Tidal on my DX150? (( Cayin N5ii worked great with Tidal.
Yes... I definitly hear someting, very quiet but i hear. Is this a bad thing?When you try to shake your DX150, do you hear any rattling noise?
zeppu08
- Jan 16, 2014
Hi! Just bought the dx150. What micro sd cards do you suggest for this? I know it can handle up to 2tb but can it load a 400gb full with ease and without issues? Or 256gb is more advisable? Thanks
NiVrA
- Apr 15, 2017
i do use 400gb thats sandisk and encountered no problems so farHi! Just bought the dx150. What micro sd cards do you suggest for this? I know it can handle up to 2tb but can it load a 400gb full with ease and without issues? Or 256gb is more advisable? Thanks
zeppu08
- Jan 16, 2014
Nice! Is it full? And btw, hows your unit? Have u resolved your problem with the lag?
NiVrA
- Apr 15, 2017
Yeah lurker helped me alot, created a new add on and it fixed my lag...its halfway full though..Nice! Is it full? And btw, hows your unit? Have u resolved your problem with the lag?
I'm loving my new DX150 on Oreo -- especially with PowerAmp V3 which is easy to sideload and install the purchase via their website. The app is much smoother than the Mango Player and is aesthetically pleasing.
This + my IT01S is an excellent 1,2 punch.
zeppu08
- Jan 16, 2014
Good to know that you are now enjoying your unit!
Total: 6 (members: 0, guests: 6)
