michelluccio
Thanks!iBasso is known for doing firmware updates when/if needed.
@twister6 Alex, would it please be possible to test out both the cards at the same time if you have the time and the patience.
I was hoping it had more from the single ended side. In comparison to other daps that have balanced output, this seems like a really big gap in power between single and balanced, like 4X vs the typical 2X.This is just a spec of output impedance (for compatibility with other IEMs and their impedance and crossover design) which is not related to output power. For the output power, DX120 has 2.5mm BAL output rated at 3.6Vrms which translates roughly to 400mW of power with 32ohm load, and 3.5mm SE output rated at 1.8Vrms which translates roughly to 100mW of power with 32ohm load.
Does anyone know the size of the Internal Memory?
Anyways, do we know what file formats this device supports yet? I'm mostly curious if it supports 32 bit WAV
Is there cover for mircosd slots?
Makes sense and makes things more confusing all at the same time. Gotta love the world of audio lol. I'm trying to decide if I need this in my life. I really like the idea of a device made specifically for straight musical bliss, with no extra doo dads and hoo haws to tinker around with. I've always preferred simplicity combined with a user friendly experience. Seems this fits that bill.The spec says PCM support up to 32bit depth / 384kHz sampling rate; that should cover 32bit WAV.
Regarding the power output, numbrs doesn't tell you the whole story. The synergy of pair up is what matters. Here is an example. I'm at work now with DX120 and have VE Zen earbuds (ZOE version with removable cable, still the same Dynamic driver with 320 ohm impedance). From DX120 on high gain from SE output I need 55/100 volume to reach my preferred listening level. Going to BAL output, I only dropped the volume to 45/100. It's not a linear relationship where the multiple of power will equate to the multiple of volume. I'm not a "sound science" guy, pretending that I know everything, just sharing what and how I hear it And btw, in this pair up, driving it BAL yields a better synergy with less congested mids in comparison to SE output. But that's probably a property of Zen's DD, being driven more efficiently with higher voltage output.
what you see is what you get in the pictures I posted https://www.head-fi.org/threads/iba...-2-micro-sd-slots.887809/page-5#post-14469926
How’d u find the DX120 compared to the Opus 1S?
