Ibasso Dx100 bugs to fix or features to add : Please tell us what you want to fix or add
Jan 29, 2012 at 4:05 AM Post #16 of 218
Was the Wifi turned on , and in the settings->accounts and syn->make sure background data is turned of as it consumes battery.
WIFI and BT - off
Brightness - minimum
Haptic Feedback - off
Background data and Auto-Sync - off
Date and Time Automatic - off
Running services - settings, music and Google PinYin input method
Jan 29, 2012 at 4:08 AM Post #17 of 218
WIFI and BT - off
Well, this is not normal at all, and unacceptable for a battery this size, 15% is too much......
Jan 29, 2012 at 4:19 AM Post #18 of 218
Well, will see if firmware update can fix this issue. Will flag it out as a bug. I had read 4ck mentioning a post on twitter reporting battery life less than 7 hours.
Jan 29, 2012 at 7:34 AM Post #19 of 218
  1. It sometimes becomes the high-speed play.
  2. Add a folder repeat function.
  3. Add stopping play if I pull headphone plug.
  4. When a screen turns off the light, I want to make volume controlable.
Jan 29, 2012 at 8:19 AM Post #20 of 218
I got a suspicion that the drain is due to the device not going into deep sleep when the screen is off. You can use CPU spy to see if your device is going into deep sleep or not.
Might be a case of the "DAP Idle" service staying active and preventing deep sleep.
Jan 29, 2012 at 2:39 PM Post #22 of 218
Jan 29, 2012 at 2:49 PM Post #23 of 218
Please may you explain....
Bugs and features missing:
2. Play tracks in reverse order
  =It is similar to this.
Jan 29, 2012 at 2:50 PM Post #24 of 218
Ok I got you, thanks
Jan 29, 2012 at 4:17 PM Post #25 of 218
It looks like Bluetooth uses battery .40%?!
I cut it and confirm it now.
Jan 29, 2012 at 8:53 PM Post #26 of 218
  • It sometimes becomes the high-speed play.
  • Add a folder repeat function.
  • Add stopping play if I pull headphone plug.
  • When a screen turns off the light, I want to make volume controlable.
1. It works best to not change the SRC settings with music playing. That often causes music to play at 2X speed. I have not had fast play happen except when changing settings while music is playing.
4. You can adjust volume after screen turns off. Screen will turn back on when adjusting volume, but will turn off again whenever
the timeout interval is reached or when you quickly press the On/Off button.
Jan 30, 2012 at 2:42 AM Post #27 of 218
"Hi,
Thank you for bug list.
We just started working on the bug list today. Hopefully, we can correct those bugs in 2 weeks.
Great jobs, you guys are wonderful. We appreciate this, even some of them arent bugs. :)
Best Regards,"
iBasso Audio
Jan 30, 2012 at 2:57 AM Post #28 of 218
"Hi,
Best Regards,"
iBasso Audio
A not-very-pleasant red packet for iBasso. But great to see they are already starting to work on the items on list.
Jan 30, 2012 at 6:47 AM Post #29 of 218
Hi, HiFlight.
1. It occurred twice yesterday. But I think that the SRC setting did not change, only playing tracks which has various sample rate.
4. I tried, but it isn't work. How did you operate it?
Jan 30, 2012 at 9:26 AM Post #30 of 218
Hi, HiFlight.
Just use the volume rocker on the side exactly like when screen is on.
