Pudu
- Oct 1, 2009
Yep, the subscription system has been tripping for weeks now. I usually click on the 'Threads' tab which seems to work better.
Also something else I noticed. The DX100 makes headphone/IEMs that have volume control sound recessed really really far back in the mids, unless you hold in the play/pause button on the volume control. Anybody else experience this? Something figgie might consider looking into.
I was using the 3.5mm socket. No adapters. I will use an adapter and try the 1/4" jack
Hey, I have my DX100! Love it!
Now that I have it, I have a couple of stupid questions:
I've read numerous times in this thread that it's a good idea to do a factory reset after updating firmware. I always assumed what was meant was the standard "factory reset" under Android settings. But then it occurred to me, there's also a "Reset" button on the side of the device.
So which is meant, the Reset button, or the Reset under android settings? And does either one wipe out your music?
Second question: Does this device support Replay Gain? If so, where might I find the Replay Gain settings?
TIA
Okay.... For the life of me I cannot get this phenomenon with my Senn Momentums, B&W P5s or Shure SE535SE nor do they sound any different with the straight through cables. Tried both 1/4 and 1/8th inch sockets.
Just a couple questions...
1. Does this happen with an App player like Poweramp as well as the stock player?
2. Do you have a third party button control app loaded to try and get the controls to work?
3. How many apps have you loaded on your DX? I'm leaving mine as a player and the only other apps I've added are a couple streaming service apps for when my mood goes beyond my collection.
Just a hunch there's some interference for some reason...
TIA
