shotgunshane
- Sep 25, 2010
I got my unit from JDS Labs which is located here in the USA. Same design but different exterior design. Well I can tell you that I find this amp superior to the Fiio E9 amp and that is a desktop amp so its really good. It does have it quirks though. If they could improve on the volume pot and come up with a digital potentiometer this amp would destroy. It does have slight channel imbalance at very low volume so for very sensitive IEMs depending on what source you are feeding it, can be an issue. But generally this isn't a problem though. It pairs very well with my full size cans. There is no hiss even with my sensitive IEMs. Its actually smaller than I anticipated and I can very well see this thing destroying much more expensive set ups.
The channel imbalance may be due to the default gain settings. Since I only use IEM's, I had mine set to 1.5x and 3x and I don't have any channel imbalance on 1.5x for any of my sensitive IEM's.
The biggest and most noticeable aspect the O2 is the utterly black background. Pretty awesome. Anyway, sorry to go off topic. Back to living vicariously through all you DX100 owners.
