bakhtiar
- Jun 25, 2001
USB related question: If you plug the D10 to PC/laptop's USB, as what device it appears?
Thank you.
Thank you.
Originally Posted by theory_87 /img/forum/go_quote.gif It doesn't affect the optical line out result so i'll pass. But i believe H320 owner will be very interested Look like I'm about to find some Elna caps to roll my D10 |
Originally Posted by EFN /img/forum/go_quote.gif Most importantly, I am really bothered with the extra bulk of my external optical DAC and despite the stellar sound, I think a properly tweaked H140 internal DAC can actually scale up to match them almost eye to eye |
Originally Posted by wolfen68 /img/forum/go_quote.gif I can understand that...but the D10 is reasonably sized enough that it's a decent compromise...and enough of a solution for my situation that I would pass on that capacitor Mod. Before the D10, I would have been tempted.... Hopefully you'll post your extended impressions somewhere for us H1xx fans to see. |
Originally Posted by theory_87 /img/forum/go_quote.gif I'm fairly confident he'll get the d10 at some point of time. Most probably after he is done wif burn in of the caps. Using d10 would be not much of different in size compare to most amp unless we are talking about supermicro |
Originally Posted by khtse /img/forum/go_quote.gif Weird. I had my D10 fully charged yesterday using the power adapter. After which I flip the charge switch to off, and plug it into the USB port of my PC and continue burring in both the D10 and my newly bought IE8, which volume set at 1 o'clock position. Just now I was surprised to find that my D10 turned itself off, with the USB cable still connected to my PC. I flipped the charge switch to on (without pulling the USB cable), and the D10 turned itself on again, with the red light below the volume knob flashing (indicating very low battery). Does this means that the D10 has been using up the battery for the last 2 days!? However, after a few minutes, the red light became steady and stopped flashing, suggested that the battery is being charged through the USB cable! How is it possible that the D10 runs on battery power and charges it at the same time, when connected to PC using USB!? |
Originally Posted by jamato8 /img/forum/go_quote.gif The D10 picks up on detail but requires burn-in time. How many hours do you have on your D10? I am using the stock opamp and the 8656 as buffers. The stock configuration is also very good, in my opinion. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif HiFlight says the AD8599 in the D10 is the best, and rivals or beats his iQube. I forget what opamps for buffers he recommended with that. I have one on the way. PS: I have the AD8599 in my modded Stax SR-001 and it kicks butt. |
Originally Posted by wolfen68 /img/forum/go_quote.gif Hey EFN, I think theory is saying "It's inevitable Mr. Anderson" |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Interestingly, the optical coax DAC section still needs the amp to be turned on, even to only use the line out. |
