arirug
- Apr 18, 2007
edit
Originally Posted by mimi /img/forum/go_quote.gif Thanks for the effort, HiFlight. Noticed that you didn't list any single supply OpAmps; is this because there isn't space in the D10 for the use of 2-to-1 adaptors? If so, did you try using a few of your favourites, e.g. AD743, AD797 without the case attached, just for the fun of it? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Go to their website and use the contact weblink over there to email them. |
Originally Posted by wolfen68 /img/forum/go_quote.gif It has a belt loop and should be perfect for some portable DAC magic while mowing the lawn. |
Originally Posted by tracyrick /img/forum/go_quote.gif That being said, this rig is still somewhat of a beast for me when exercising. |
Originally Posted by HiFlight /img/forum/go_quote.gif There is not space for a DIP case style, but single-channel SOIC opamps mounted on the stacked Browndog adapter will fit. It is a very delicate soldering operation to mount these. The AD797 will not work due to voltage, but the OPA627 sounds magnificent when coupled with the AD8656 used as buffers! Sort of like driving a Ferrari...Very expensive, great performance, but you can't go very far on a tank of gas! I expect battery life to suffer from this combination. I will try get an approximation of play time for this combo. I would have to say that to my ears, this combination is right up there with the best home amps! I still have some other opamps I want to try when I get them mounted on adapters. I will add to my list as I find others that are compatible with the D10. |
Originally Posted by immtbiker /img/forum/go_quote.gif You guys are lunatics. ![]() Even if an IEM sealed out 32db's of ambient noise, why would you use a dac/amp combo when exercising or lawn mowing... |
Originally Posted by immtbiker /img/forum/go_quote.gif The whole idea of using an iMod/amp combo or a DAP as a transport with an optical out, using a Predator or Pico or iBasso amp/dac combo, is to get the best presentation of a lossless file in a portable setup. Unless you are fully concentrating and totally immersed in the music, without any outside interferences, then all of this seems unnecessary to me. Overkill, so to speak. |
Originally Posted by immtbiker /img/forum/go_quote.gif You guys are lunatics. ![]() Even if an IEM sealed out 32db's of ambient noise, why would you use a dac/amp combo when exercising or lawn mowing (this is not meant to be a personal attack on anyone, I am just using the quotes for references). The whole idea of using an iMod/amp combo or a DAP as a transport with an optical out, using a Predator or Pico or iBasso amp/dac combo, is to get the best presentation of a lossless file in a portable setup. Unless you are fully concentrating and totally immersed in the music, without any outside interferences, then all of this seems unnecessary to me. Overkill, so to speak. |
Originally Posted by wolfen68 /img/forum/go_quote.gif I use a custom IEM with "industrial grade" earmuffs. The double hearing protection/isolation is very effective at making lawn mowers and chainsaws only a distant minor impact on the listener's enjoyment. |
Originally Posted by tracyrick /img/forum/go_quote.gif Holy crap! I've always wanted to try that, I was wondering if anyone else ever had. Only thing stopping me is I don't have the earmuffs. My thought was doing that for long plane rides, earmuffs on top of IEMs. Totally brilliant. Only downside is your stuck with carrying the earmuffs too, so you're not quite as portable anymore. |
Originally Posted by jamato8 /img/forum/go_quote.gif So you used a dual adapter for the 627? ...............................snip............... ........................ |
Originally Posted by wolfen68 /img/forum/go_quote.gif I use a custom IEM with "industrial grade" earmuffs. |
