iBasso D10. .UPDATES 1st page, with Current Opamp Choices by HiFlight . . . images page 1, 12, 13, 14, 15, 21, 71
Mar 18, 2010 at 11:56 AM Post #3,886 of 4,153
Got my Mini-Audio/Ibasso D-10 today. Here are some pictures. Do the ibasso owners see any differences in the build except for the print? It sounds great
Mar 20, 2010 at 10:56 PM Post #3,890 of 4,153
I accidentally cracked the optical connector, it still works but anyone was able to replace it?
Mar 21, 2010 at 1:40 PM Post #3,891 of 4,153
Just ordered hiflights topkit for the D10. I have a pair of IE8 and Denon D5000. Any suggestions as to which opamps will be best for a combined use of these two headphones?
Any answers will be much appreciated.
Zai: I dont know, but you could send a mail to ibasso asking them for spare parts or for a warranty coverage.
Mar 21, 2010 at 2:51 PM Post #3,892 of 4,153
After installing the Topkit, both phones will work well without changing any of the Topkit opamps.
Ron
Mar 21, 2010 at 3:51 PM Post #3,893 of 4,153
yes, the topkit IS opamps, not sure why you bought the topkit and are asking what opamps you should use
Mar 21, 2010 at 4:28 PM Post #3,894 of 4,153
It is a through the hole connector. You could ask iBasso to send you one in the mail and have any decent tech take out the old one and replace it.
Mar 21, 2010 at 9:49 PM Post #3,895 of 4,153
gusp: I am new to op amp rolling. And thought that the op amp kit consisted of many different op amps. Thank you for clarifying that for me
I got the kit recommended by a friend without really knowing much about it.
Mar 21, 2010 at 10:48 PM Post #3,896 of 4,153
@klekk & jamato8:
Ok, i'll contact iBasso for advice.
Mar 24, 2010 at 3:03 AM Post #3,897 of 4,153
At work I use a different rig than at home.
I tried two different setups:
Foobar WASAPI -> Firewire -> Firewire 410 -> Optical -> d10 (headphone out) -> Gilmore Lite -> cd3000
Foobar WASAPI -> Firewire -> Firewire 410 (1/2 Output) -> Gilmore Lite -> cd3000
For a few days I listened to the first setup and was pretty pleased, after I finally got an adapter hooked up to the fw410 to use its outputs...
I found that the d10 as a DAC via optical fared worse than the fw410 as a DAC; it was like the bass wasn't as well rounded on the d10 and couldn't keep up. I could also hear more coloration with the fw410, especially apprent with extreme high frequencies (it kind of hurts) as a result of this. I would venture to say too that the detail was better with the fw410.
I do recognize that volume matching at that point gets difficult, but do you guys think that there's some flaw in my setups here or would this seem accurate?
Mar 24, 2010 at 4:22 AM Post #3,899 of 4,153
Originally Posted by Mr Do /img/forum/go_quote.gif
You use the line out of the D10 instead of the headphone out when connected to an amp.
I did that too but stuck with the HP out due to Jamato's recommendation!
