viator36
- May 28, 2005
qusp: Not answering for jamato but want to give you the measurements I got. With the two pieces joined together the total length from edge to edge is 42mm. So that's 21mm each. As I mentioned my piece from tip to tip is 28mm. That would mean from tip center spot to joint surface is 14mm. You must have noticed on top of the adapters (opposite the tip side) there is a small dent. I believe that's the tip's center spot on the back. I used that to measure tip to joint surface line. Of course you add some extra length for joint surface trimming and polishing.
Originally Posted by qusp /img/forum/go_quote.gif jamato: you didnt happen to take note of how far in you made the cut did you?? or did you just measure where it would be if you joinde them together whilke the iriver and D10 are mated?? |
