iBasso D10 crackling noise with my Sennheiser HD650s headphones
May 11, 2010 at 7:38 PM Thread Starter Post #1 of 6
Earbuds
What's wrong with my computer? I've been trying to use my ibasso d10 amp with my sennheiser hd650 headphones and whenever I do it always has a crackling noise. It'll be fine for about 20 seconds, and then it'll crackle for 1-2 seconds and then go back to normal for a bit and randomly crackle.
It doesn't crackle with my iPod or my spare computer, but it does on my main computer and that's a big problem. I don't know how to fix it
What should I do? This is my computer http://www.newegg.com/Product/Product.aspx?Item=N82E16834220527&cm_re=w90vp_x2-_-34-220-527-_-Pr
oduct
I know the d10 isn't strong enough to drive the hd650s, but I don't think it would cause the crackling.
May 11, 2010 at 7:52 PM Post #2 of 6
Well, if you can run the 650's with the D10 off the iPod and other comp, you pretty much have done troubleshooting to the computer.  Are you hooked up to the D10 via USB?  Are there any possible USB conflicts or grounding problems with the comp?
May 11, 2010 at 7:57 PM Post #3 of 6
I've used 4 different USBs on this computer and it's all the same. As for grounding, I honestly don't know what that means. It's a laptop, so I usually keep it on my lap or on my bed. It's not on a desk or anything. The D10 is also on my bed.
May 11, 2010 at 9:32 PM Post #4 of 6
Can you try your D10 with another computer?
