iBasso CF01 (Cable Free), BT MMCX adapter for any MMCX IEM.
May 21, 2021 at 12:29 PM Post #196 of 209
Which adapter did you use? Did you need it because of recessed MMCX connection on your IEMs?
I'm using OE Audio's adapters since they're about half the length of a standard set as you can see below:
With these adapters, yes. That's been the whole goal behind the journey I'm currently on; figure out what the CF01 can't power adequately or connect to. As far as I know, only IPX (edit: and JH's 4 or 7-pin connectors) is off the table at the moment; haven't been able to find a suitable adapter for that.
May 21, 2021 at 12:41 PM Post #197 of 209
With these adapters, yes. That's been the whole goal behind the journey I'm currently on; figure out what the CF01 can't power adequately or connect to. As far as I know, only IPX is off the table at the moment; haven't been able to find a suitable adapter for that.
I think I'm just confusing myself here but do you know which adapters I need for the Sennheiser IE 300?
May 21, 2021 at 12:44 PM Post #198 of 209
For the IE300, you might be out of luck; it looks like they've tried really hard to make that cable proprietary while using standard connectors. Man, what an Apple move...
If anything, reach out to OE and see if they can't do something custom for you. I have a feeling their connector is narrow enough to fit in that socket, but wouldn't have the means to measure and verify for myself.
May 21, 2021 at 12:54 PM Post #199 of 209
Thanks for the recommendation. OE just got back to me quickly and said: "Our adapters does not fit with ie300, since ie300 isn’t a standard mmcx product." and they said they can't produce a custom one 😪
May 21, 2021 at 12:58 PM Post #200 of 209
All but confirms Sennheiser went semi-proprietary on that connection. Shame on them. I'm sorry, bud.
Oct 11, 2021 at 8:10 PM Post #201 of 209
Hi all - has anyone had issues with one side not charging? I've not had mine long (love the sound!) and use them for running. Left side is either not charging at all, or not charging past a certain point. I tried running the right side down in the thought that maybe once the right was full the left stopped....but it doesn't seem to have worked.
I can't charge the left past 60% and it's often at 50%.
Any thoughts/experience/solutions? Currently thinking I'll need to send them back to iBasso which is a pain...
Oct 13, 2021 at 2:07 AM Post #203 of 209
You're best bet seems it's a warranty issue...
The good news is you still can go wired. :sweat_smile:
Still love my CF01/LZ-A7 combo.
Haha! Yeah, wired is absolutely my preference. However my phone doesn't have a jack. I have a dongle for listening (Ovidius B1, with UM Mest - very nice) but for running and for phone calls, I chose to go with wireless. Also, I do not want to use my Mest for running since I sweat like a waterfall!!!
Nov 21, 2021 at 11:42 AM Post #205 of 209
Hello, can anyone help me, my CF01 right side keep blinking fast blue light. It can't connect to left side. I even can't connect to my phone.
I would look at the manual. I would to a long hold on the CF to reset it and then delete it from the BT device and then add it back.
Jul 23, 2022 at 5:33 AM Post #206 of 209
Guys, any news about updated CF01? Something like CF02 or CF03? They don't even mention the CF01 on their official website. Longer battery life and LDAC would be much appreciated.
Jul 23, 2022 at 6:03 AM Post #207 of 209
I was wondering the same and wrote to the iBasso support. Unfortunately they told me they are not planning to release a successor to the CF01 :sweat:
