PixelSquish
Previously known as idiotekniques
- Jul 13, 2005
I have a like-new CF01 for sale in the new classifieds. Cheers!
And here are all 3 models compared
It's a tight fit on standard connections as is. Don't think you're going to make it work on recessed cups without an adapter. Have you considered some OE?Anyone had issues with the MMCX connector fitting their IEMs? My Sennheiser MMCX connection is recessed and my CF01 doesn't go in far enough to click and make a proper connection.
I have no issues with any IEMs but I can see that an MMCX could be a problem but I never liked the deeper recessed MMCX connector.Anyone had issues with the MMCX connector fitting their IEMs? My Sennheiser MMCX connection is recessed and my CF01 doesn't go in far enough to click and make a proper connection.
Do you know if an adapter or workaround exists?I have no issues with any IEMs but I can see that an MMCX could be a problem but I never liked the deeper recessed MMCX connector.
Theoretically, you'd just need a deep socket adapter that terminates in either MMCX or 2-pin. OE has a couple.Do you know if an adapter or workaround exists?
Which adapter did you use? Did you need it because of recessed MMCX connection on your IEMs?Now that I have the OE adapters in, I can finally speak on fit inside the case. Decided to break out some of the bigger boys to put this theory to the test...
I mean I did pluralize it...Moondrop Blessing 2 with the Dunu DK-3001 Pro sitting in there just to simulate even more size. Case closes just fine without interrupting charging and nothing moves. Have zero complaints about this case and, as you can see, it'll still close even with the OE adapters attached.
I've said it before, but I'll say it again. Bravo, @Paul - iBasso ! You and the rest of the team should be extremely proud of developing this product. It's a veritable powerhouse, even giving the P1 enough current to have some seriously shining moments, but it's honestly impressive just how powerful the Blessing 2 sound here. Still have a bunch of 2-pin IEMs to go through, but we're off to a really good start so far.
Perhaps in future iterations, you can upgrade the BT radio. There are moments where I get signal dropouts if I put my phone in my back pocket, even if it's on the same side as whatever ear I'm using at the time. It's honestly the only real complaint I have with the entire unit.
Like this?: https://www.oeaudio.net/product-page/mmcx-to-ciem-adapterTheoretically, you'd just need a deep socket adapter that terminates in either MMCX or 2-pin. OE has a couple.
Honestly, it might be worth it just for the reduced strain on the in-built connector.
