rincewind
- Oct 28, 2004
You shouldn't need to try hard to hear differences. Like others have said, get lossless files now. Don't put garbage in, you'll only get garbage out. Use ASIO like others have said. Turn off all plugins, EQ, crossfeeds etc.
The difference the amp should make to the cans is 'weightier' bass with more control and also probably pushing the frequency response lower. Highs should seem cleaner. There may be more soundstage. Anyway, also as said: listen using the Pico/HD650 for a solid month (no A/B'ing!!) then go back to the old setup. I'm 99% sure you'll go "bleh! something is missing now" when you go back to the old setup. Some people believe you can tell differences from A/Bing whereas others think you need much longer to get used to a change. I believe the larger the change in the sound, the shorter the time you need to get used to it. Give it a month and see.
Oh and one more thing, do this: sit there with the PC on and no TV's or anything else that make noise turned on. Then turn off the PC. Most ppl will notice the power supply fan hum gone, the video card fan whine gone, the hard drive whiz/clicks gone. If yours makes any of these noises, this is a background noise that you're struggling to listen over - it'll cover up small details. One of the best things I ever did was silent treat my PC so that now I can barely hear it a 3 feet.
