iHead
- May 12, 2008
In my opinion EMU 0404 and Behringer 2030 is best low budget set-up.
Originally Posted by chiefroastbeef /img/forum/go_quote.gif Hello guys, I recently got a Macbook Pro, and I'm considering speakers(A2's). My Superfi's are too uncomfortable after a while of listening(memory wire). Anyways, what is the most economical setup for a MBP and a pair of A2's? I'm not too sure how it works.. seems like I need a DAC? or some people recommend the EMU 0404? Thanks! |
Originally Posted by coredump /img/forum/go_quote.gif I built some small stands for my A2s using my awesome carpentry skills. |
Originally Posted by NeoVibe /img/forum/go_quote.gif Can anyone compare the A5's with the Yamaha's HS50M? (I can audition the HS50Mbut not the A5...) For reference, I've also been told that the HS50M are much better than M-Audio bx5a... thanks |
Originally Posted by Operandi /img/forum/go_quote.gif I believe Audioengine lets you try the speakers for a trial period (though that may only be for North America?). As for the Yamahas technically they sound better; they are bi-amplfied and feature active crossovers, the A5's feature neither. I haven't heard either but the Yamahas being pro monitors will mean they should have a very flat response. The A5s being more of a consumer speaker wouldn't necessarily aim for such a neutral response. Where you consider better would be largely personal preference. |
