- Sep 3, 2006
The "subjective experience" is also what gave some folks their belief in Bigfoot, Nessie, UFOs and Mermaids. They know what they saw - nothing else matters.
RD, you are a better man than I. You're still holding out hope, trying to convince people. I gave up long ago. Maybe it's time you did too.
Originally Posted by billybob_jcv
I think the inner workings of the ear->nerve->brain are irrelevant. The input signal to the ear is differential pressure across the eardrum. Describe that accurately, and you have described the entire audio spectrum. Anything else after that interface is *created* by the listener's components in the system (ear, nerves, eyes, skin, nose, tongue, brain).
Yes but those are different. Enjoying music is an experience. A subjective experience. There are truths to audio signals, which we can measure and narrow things down and help to cut down on the snake oil, but you can't have just measurements. Gear doesn't just have to measure well, it has to sound good. Usually those go hand in hand, but we need subjective affirmation of the measurements to make sure we are measuring the right things in the right way.
We need both.
here are certainly some folks that go to far on either side of the spectrum.
These guys should quit the audio hobby and get into the measurement hobby. The measurements are clearly more important to them than the music.
We need both.
and claiming that the Odac is just as good as every other dac ever made.
You are missing the point. Consider basic systems engineering. The listeners head is a black box. The input to that black box is all of the stimuli received. That is ALL that can be affecting the black box. Inside the black box can be all the magical deciphering you want to consider - but the input stays the same. The audio signal being transmitted to the black box is a time-varying 3-dimensional differential pressure that strikes the ear drum. If you know of some other input being delivered to the listener, please enlighten me. If you want to consider each ear separately, fine - each ear is presented with a different differential pressure gradient.
My point is that it was stated that you can't measure everything, therefore you can't know by measurement whether two systems are actually identical. I claim that if the two systems produce exactly the same time-varying 3-dimensional differential pressure, then they are producing exactly the same sound. All the nonsense about "complex music is different than sine waves" really boils down to air pressure - that is what sound is.
The question you should be asking yourself is whether the time-varying differential pressure can be captured in a way that is at least as accurate as the human ear.
I'd like to have my cake and eat it too. Music is fun, learning acoustics is fun, analyzing measurements is fun. My favorite is actually the psychological aspect of perception, subjective experiences which can be studied objectively (if that makes any sense).
You're limited by the polar response of a speaker and room interactions. Unless you're listening from the sweet spot you will not get the illusion of a well-defined sound source when listening to a recording through a set of speakers. So we're far from creating a 3d sound field that can approximate a real live performance.
What we can do is combine recordings, sound synthesis and environmental modelling algorithms to render an interactive 3d scene, as in modern videogames. It is conceivable that an audiophile videogame can be created where you can experience the joy of waiting in line, sitting in the back of the orchestra hall and hearing people coughing around you in glorious 3d!
Yes. There is, believe it or not, a middle ground between buying a rainbow colored assortment of inch thick 800 dollar USB cables and claiming that the Odac is just as good as every other dac ever made.
what's the difference between listening to an $800 USB cable and thinking that it's much better than a regular cable and listening to a $1000 DAC and thinking it sounds much better than an ODAC? because u know for a fact that USB cables don't make a difference? well, the USB cable believer doesn't know that, otherwise he wouldn't think that right?
I'm afraid answering this question requires common sense.
