Originally posted by JMT
I don't find my HD600s to be shy in the bass. If fact, I think that they have some of the deepest bass that I have ever heard. But, if you are comparing them to the V6s, then I can see your point. |
From where I sit, the HD600 does not go as deep as the Sony V6. Not many do. Please keep in mind that in this I'm only talking about extension--the quality of the bass in the Sony V6 isn't all that great (though, I still say it's great for the money).
A preference for the V6 over the HD600's bass could mean any of these things (that everyone is sort of hitting on):
Listener prefers tighter bass (HD600's bass is looser, especially on lesser amps)
Listener prefers tactile bass feedback (HD600's bass becomes more tactile on greater amps)
Listener prefers further bass extension
Listener prefers an exagerrated bass/midbass response (HD600 is already exaggerated, V6 is further exaggerated)
(I hate that I have to explicitly state this but...) None of these preferences should be considered some kind of insult. Liking more bass than flat is perfectly fine -- and often necessary to get back up to near flat with portable sources, soundcards, etc. and even very good sources with bad recordings. (You shouldn't feel you need someone's permission to have a preference anyway but I thought it worth stating since I'm so utterly offending when I say things like this.)
Ok, now my point here is this. If you want the
bass extension of the V6 but don't want the bass/midbass emphasis, there is Etymotic ER-4S, Grado HP-1000, Stax 007. I haven't gotten to fully evaluate the Beyerdynamic DT770 yet but I'd suspect it also capable of deep bass.
If you want
tactile bass feedback, absolutely avoid the Etymtoic and Stax line. The Grado HP-1000 is still an option and the DT770 fans will almost always chime in here.
If you want
tight bass response, the Stax, Etymotic and all of Grados old and new lines I feel excel at this. Again, I'm not sure about the DT770. The DT931 is tighter than the HD600 and there are some threads here about how to bump the bass to balance the frequency response (replacement cable, 120ohm adapter).
If you want
bass/midbass frequency response emphasis, the DT770 is probably the one to get. Even from my brief audition, it was immediately a very warm sounding headphone. In this case, avoid the Etymotic, Stax and both generations of Grados. The HD600 is more exaggerated than most but nowhere near the DT770.
